Hi there,
I would like to enable the substitutions function to have my own tags, for my module, and unfortunatly it does not work.
I did follow the how to: https://wiki.dolibarr.org/index.php/Create_an_ODT_document_template#Other_personalized_tags
And I read the various posts on this topic (which seems to be a reccurring issue to make it working right!) but for completion:
I have my own function in the /custom/mymodule/core/substitutions/functions_mymodule.lib.php
the function name is “function mymodule_completesubstitutionarray (…) { … }” -
mod.class.php does have the entry ‘substitutions’ => 1,
entry in DB in llx_const exists as main_module__substitutions with value 1
tags is {bpBirthDate} and has been set properly in the ODT template (for info the other standard “tags” work well)
the main object for generating the ODT doc is the 3rd parties (societe in French) -> no specific customizing whatsoever exists, “on the shelf object” from the V11.
Any help would be appreciated.
Thanks and best regards
Gwilhom
