Ya solucione el problema de la facturación A y B, cualquier consulta sera bienvenida.
The numbering of invoices every month beginning from 1
eg.
INV 001/02/2016
INV 002/02/2016
INV 001/03/2016
What is the “mask” you used for your invoice numbering ?
Is possible to have this solution on Dolibarr 4.0.4?
I tryed but not works!
Hi a newbie to dolibarr here
It is possible sir to make different sequence of number in different customer like cus1 should be start in 1 and cus 2 also should start in 1?
Thanks and best regard
You can use the numbering rule “mercure” so you can include the tag {t] to have the type of customer inside the number.
If you really need also a number specifi to each cutomer, you can also include the tag {ccc0000} to include also a counter dedicated to customer code
hello,
This is very nice software(Dolibarr5.2). i But i need to chenge something and i’m stuck for few hours.
I want to change invoice name/namber from FA1705-0001 to 3DPM0050.
I’m very new, maybe it is very simple, and it is a stupid question.
Pease can you help me… with some steps to make the modification. Wich is the file or line where should i make the modification?
Thank you
multiple invoice type…not on customer basis it will factory location specific…is it feasible?
for example:
Factory A having invoice no. as A-0001
Factory B having invoice no. as B-0001
or department wise numbering i.e.if having 2 departments X & Y…
this invoice number should be X-0001 for department X
and Y-0001 for department Y
Hello.
Is it possible to translate {ttt} because in Greece we need Greek characters on invoice.
I need to make {ttt}-{0000}
TE_APY to export on invoice ΑΠΥ-0001
TE_TPY to export on invoice TΠΥ-0001
TE_DA to export on invoice ΔΑ-0001
etc
Thanks in advance.
George
hi! do you have resolve= i need also for me this solution please
