Thanks for your reply.
Not a developer, but can do some troubleshooting… self learning.
Well then I dont see a way ahead with this sync process…
I guess Dolibarr developer should seriously consider developing report printing in Accounting, so that the output will be in standard format of accounting.
I hope developers are reading us.
Thanks.
[color=#0044ff]You can use the QuickBooks mobile app and use sync with your QuickBooks account. You will sign in using the same login credentials. If you are using an iPad, make sure you download the Mobile app and not the QuickBooks Online for iPad app. You will need an online account for that app. Contact Quickbooks cloud hosting support they will help you.
