Add copy of original on invoice if we need to re issue invoice
I want to add line mentioning 1st copy of original, or 2nd copy of original …if we reprint all type of invoices. How to achieve the goal
I want a :coffee:
A bit of courtesy is a must !
For your question, Dolibarrr creates PDF, printing is out of Dolibarr (on your PDF viewer tool) so Dolibarr doesn’t monitor it.
then can we add same feature if we re generate pdf files…
Invoice are not supposed to be modified.
Proposal yes, and you have external module for that :
Just to clarify the need, are you looking for copy tracking on the same document, like printing a duplicate or triplicate for shipping or record purposes? If so that’s a PDF customization.
Or are you looking to reissue the invoice with actual changes, like a revised version that keeps the same base reference but is marked as revision 1, revision 2 etc, while the original is marked superseded and excluded from your financial totals?
If it’s the second case, that’s a proper document revision workflow and there’s a module for it on Dolistore. DocRevision handles exactly that across proposals, invoices, sales orders and purchase orders: DocRevision — Document Revision Tracking for Dolibarr
