Hi
I’ve installed the module UltimatePDF 5 on 5.0.4 and there is an issue with the colors genrated in the PDF documents and the module developer does not have an imidiate answer. As it work as it should on the developers installation it could maybe have something to do with my installation.
When making a background color to use in the fields of the PDF documents generated, only a few Hex colors work; the most color codes will not be displayed at all in the PDF document so the background will just be white. As an exemple CCCCCC does not work but 0099C works just fine. NOTE: this is with the exception of one filed where the background color always is visible.
Does anyone have any clue about where to look?
All the best
Hans
It works at my end
I have tested the UltimatePDF module on Dolibarr >=5 stable, =6 beta, =7 alpha and never had any problems with the colours. Is that a standalone version or in a cloud?
Hello
Sorry, I havn’t noticed your answer earlier
I have the installation on my own Linux-Debian. The server is indeed on Microsoft Azure Cloud but it should not have any impact. It is a Debain with Virtualmin installed on.
I run it in Apache mod_php but have tried FCGId as well. For the moment it goes under its own domain (subdomain). Right now I run it on an absolutley clean server setup running on PHP7.0.I changed server 2 days ago and the problem remain.
Dolibarr 6.0.3 and the lastest vesion of the module.
So what can this be? Any php settings?? Missing some module on the debian server?
All the best
Hans
