Display problem Internet Explorer 11
I have a problem with the new installation of Dolibarr 4.0.4 on Centos 7, using Firefox everything looks great.
However, under IE11, the top menu does not display correctly. Can anyone help me?
I tested with 4.0.6 and IE11 and do not experience any troubles. Try to upgrade to 4.0.6
Do you have IE plugins installed ?
Thanks for replay,
upgrading to the higher version did not solve my problem, but get me closer to the solution.
Dolibarr is on the local server and I had the proxy enabled in Internet Explorer (with “do not use a proxy server for local addresses”).
I do not understand why but after turning off the proxy server in IE - the problem has disappeared. I checked the proxy server logs and there are no connections from my machine or the Doli. For some reason, turning on the proxy in Internet Explorer causes the Doli pages are display incorrectly.
