Good morning dear friend I write him the following have following problem when trator to configure keep everything as they say, I’m Venezuelan would like to know what may be the solicion I get this
Warning: include (tax_rates / ve.php): failed to open stream: No such file or directory in /home/u400189704/public_html/wp-content/plugins/doliwoo-develop/includes/class-wc-tax.php online 72
Warning: include (): Failed opening ‘tax_rates / ve.php’ for inclusion (include_path = ‘.: / Opt / php-5.4 / pear’) in / home / u400189704 / public_html / wp-content / plugins / doliwoo-develop /includes/class-wc-tax.php on line 72
Warning: Invalid argument supplied for foreach () in /home/u400189704/public_html/wp-includes/functions.php on line 3194
Warning: Invalid argument supplied for foreach () in /home/u400189704/public_html/wp-content/plugins/doliwoo-develop/includes/class-wc-tax.php on line 104
Warning: array_map (): Argument No. 2 Should be an array in /home/u400189704/public_html/wp-content/plugins/doliwoo-develop/includes/class-wc-tax.php on line 121
Warning: implode (): Invalid arguments passed in /home/u400189704/public_html/wp-content/plugins/doliwoo-develop/includes/class-wc-tax.php on line 122
The thing is that WooCommerce and Dolibarr differ significantly in the way they handle taxes. To resolve this discrepancy we need correlation tables for each country. The one for Venezuela is not available yet.
On a side note, I see that you’re running a version from the development tree. You really don’t want to do that are thing are bound to be broken during the development. You should rather use a stable version you may find packaged at https://github.com/GPCsolutions/doliwoo/releases
Replacing the webservices folder is reckless.
Tables have changed between 3.6.x and 3.7.x. You’re calling for trouble!
Please see: https://github.com/GPCsolutions/doliwoo/issues/77 for a proper fix.
Hi rdoursenaud,
i tried your plugin, it looks promising and its almost working - so far created products in Dolibarr will be exported to WooCommerce.
In dircection WooCommerce to Dolibarr there is a problem:
By submiting the order “Buy now” dolibarr is not creating the data into Dolibarr-Sytem.
The checkout process stops, forwarding to the “Thankyoupage” is not happening.
The Konsole in Firebug reports this:
TypeError c is null
c.redirect:window.location=decodeURI(c.redirect)}catch(d){if(“true”=…
(/wp-content/plugins/woocommerce/assets/js/frontend/checkout.min.js?ver=2.5.2)
If i deactivate the action / the hook in doliwoo.php ‘woocommerce_checkout_order_processed’
the script will run trough without problems , create the order and forward to “thankyoupage” at the end of the checkout.
But of course, the is no entry in dolibarr at all…
Did you notice a similar issue already?
Do you have any idea how to fix that problem?
many thanks!
p.s. Versions of Dolibarr, Doliwoo and WooCommerce are the latest ones…
Iam Using Dolibarr 3.9.0, i traing to sysncronisade woocommerce to Dolibar, ist ther a manual or a video where i can see how i can install the plugin and make work ? , ist pocible to manage orders fron woocomerce in dolibarr ?
Use woocommerce version 3.1.1 and dolibarr version 5.0.4.
1 - Activated the module "Services API / Web (SOAP Server).
2 - I generated the dolibarrkey parameter.
3 - But in woocommerce it asks for a URL https: // mydolibarr / webservices. When I’m going to save I get the message "The webservice is not available. Please check the URL)
But woocommerce detected the version of Dolibarr.
Can someone tell me why they are giving this error? What is the correct URL?
I don’t remember how I set it up in past when I was testing the module but I think there was something to do with “https” try without at the end “s” e.g. http: // mydolibarr / webservices
you can also have a look into readme.txt file that is inside the zipped file.
Hope that helps
and leave it for some time (in my case it was at least an hour for over 700 products) if it doesn’t work then try with
and again leave it for some time to synchronise. Let us know about the outcome. If it doesn’t work I’ll try myself this weekend as I’m sure it worked for me just don’t remember how I did it.
P.S.
The link to web services should look like this
