Hi!
I’m using dolibarr for two years now, and I was wondering if there is a way to edit the invoice title and reference, replace them with whatever I want, and add the unpaid amount after the total.
Does anyone know how to do it?
Best regards.
Hi!
Best regards.
Hi @badakchiche
What do you mean by “invoice title” and “invoice reference”?
If your need to change some wording on the invoice, try “translation” in the Setup menu.
As to, invoice reference, if you mean “numbering model”, you can set it up in the settings of the invoice module. Normally, but depending on the rules in your country, you cannot individually edit the reference number of one invoice.
As to the unpaid amount on an invoice, once you have entered a paiement for an invoice, you can re-edit tne invoice pdf. Then, the unpaid amount will appear on your pdf.
