If the project module is turned off, the contact is displayed normally. If you enable the project module, an error occurs
ksar
2
What type of SQL server are you using ?
I’m assuming it’s PostgreSQL?
If yes can you create a bug on Issues · Dolibarr/dolibarr · GitHub ?
Thanks
Hi!
PostgreSQL 13x is used on FreeBSD 13.2
So far the issue has been resolved by adding the project and external columns (char) to llx_c_type_contact
Best regards,
-D. Petrov
ksar
4
In fact the problem is just because of " instead of ’
on lines :
I will push a modification
