Hi
ksar
kindly give me instruction to change
Check the rights of the user.
Hi
ksar
You need to give the user full rights. It needs to be a super user or DBO user.
Hope this helps
hi
can you provide little more information
how me can do this?
I have never used awardspace, so not sure how it works.
Did you create the database user?
If you give me access I could have a look for you but not really the best option
may i provide teamviewer access?
I think its best just to find your root user for the database. I would be happy to login and check. But you can ask your service provider also
Contact your hosting compagny to know how to do it.
Or, as it seems that you have limited skills in webhosting, prefer a Dolibarr Cloud service. It will be safer for your data’s.
Remember that you will put all the sensitive data’s of your company on this software, better to spend a few dollars per month to be safe.
https://wiki.dolibarr.org/index.php/Cloud_Solutions_for_Dolibarr_ERP_CRM
