Very often we copy propales with many productos in order to create a new one. Sometimes we need to remove 10 or more products, and this means that I need to remove then individually… 10 or more times!
I had a look in dolistore but I could not find any module for this purpose. Did I missed anything? Any recommendations or suggestions?
Hi. Yes, I’ve been looking for that too. Momentarily my solution is to use a feature in the module “subtotal lite” by ATM. You can then quickly create a title, and everything that will be under it can be removed in one go with that same title. If you need to remove not all the last lines, you have to add a subtotal line at the end of the block to be removed. Cheers.
Another solution, instead of just copying is to import just the lines you need in a new proposition. There’s another module for this, called “import proposal lines” or something like that. Cheers.
