Hello.
I have a CSV containing many thousands of products along with their stock levels. Is it possible to import these stock levels along with the products?
There doesn’t appear to be a predefined option for this in the import module so how would I go about modifying the module or manually adding these values to the database? (I can’t sit and add these figures through the web interface, it’ll take forever ).
You might want to start here, instructions on how to create your own module, then you’ll be a little more familiar with how the module works and the core files you’ll be modiying.
i faced the same challenge;
for adding the stock manually to the database, you must have a list of row_id from products table, that you will put alongside the CSV listing of your products on a spreadsheet. make sure the file columns match the table structure of the Product_stock table, with the row_id column matches the products row_id from the products table, then import straight into the Product_stock table, using any MySQL management tool.
you have to be careful the row_id of the product matches its stock detail on the same CSV file, otherwise you might have products’ stock mixed up, like 50 for product X instead of Y. i found it easy though…
