Hi Eldy, after trying to upgrade from 3.1.1 to 3.2.0 I had this errors in my log and an unfinished upgrade script.
Error DB_ERROR_1452: ALTER TABLE llx_propal ADD CONSTRAINT fk_propal_fk_user_author FOREIGN KEY (fk_user_author) REFERENCES llx_user (rowid);
Cannot add or update a child row: a foreign key constraint fails (dolibarr2
.#sql-2f5_3e2
, CONSTRAINT fk_propal_fk_user_author
(rowid
Error DB_ERROR_1452: ALTER TABLE llx_propal ADD CONSTRAINT fk_propal_fk_user_valid FOREIGN KEY (fk_user_valid) REFERENCES llx_user (rowid);
.#sql-2f5_3e2
, CONSTRAINT fk_propal_fk_user_valid
(rowid
Error DB_ERROR_1452: ALTER TABLE llx_propal ADD CONSTRAINT fk_propal_fk_user_cloture FOREIGN KEY (fk_user_cloture) REFERENCES llx_user (rowid);
.#sql-2f5_3e2
, CONSTRAINT fk_propal_fk_user_cloture
(rowid
Error DB_ERROR_1452: ALTER TABLE llx_commande ADD CONSTRAINT fk_commande_fk_user_valid FOREIGN KEY (fk_user_valid) REFERENCES llx_user (rowid);
.#sql-2f5_3e2
, CONSTRAINT fk_commande_fk_user_valid
(rowid
your help will be very appreciated.
I did try the /install/repair.php and restart the upgrade 3.1->3.2 more than once without positive results. Further assistance will be appreciate.
regards,
Gregorio
