In the Barcode type there is a QR-code module under Barcode type if you pick Qr Code then the input is for Barcode value which is different then a Qr code value. what module does this use and where can I change the validation or build a Qrcode value which you can put a https://website.com as a value?
Or better yet the input switches to Qrcode vs Barcode value.
