PHP Help for 19.0.2
Hi
Have upgraded to latest version 19.0.2 on cloud, if i use php version 7 all works fine, when i change php to 8.1 i get blank page ?
I can speak to hosting but they were saying either 7 or 8.
If i use 7 dolibarr works and osticket does not and
if use 8 osticket work and dolibarr does not.
I was under the impression that newer versions support php 8 and above ?
Update have tried PHP 8.1, 8.2 and 8.3 with no success ?
do you possibly use any external modules which are not compatible with php v8?
Nope standard install
Have a look to the PHP logs
How do i do this please ?
What is your hosting company ?
Ask your hosting company
Hostgator is the hosting company
https://www.hostgator.com/help/article/internal-server-error-help-500-error
