I am not able to sync the product data between Prestashop and Dolibarr.
Prestashop 1.7.6.7; Dolibarr 12.0.1
Other information such as categories are syncronizing just fine.
I would really appreciate any help in this regard.
Which external module are you using to do the synchronization ?
Thnx for reply.
Prestashop to Dolibarr PRO
v2.0 - by PJ Conseil
According to the module page :
- Dolibarr min version: 7.0.1
- Dolibarr max version: 9.0.*
- Prestashop min version: 1.6.0
- Prestashop max version: 1.7.*
So it is not supposed to work on V12. It is V9 max.
But you can try to download the latest version from Git : https://github.com/johanbernard/prestashop_to_dolibarr
That would be a real bummer
But actually I did download this module from GitHub.
And perhaps I just have to find some other module to do the sync job or sync manually.
Splash can do this. https://www.splashsync.com/en/modules/dolibarr
I am facing the same problem and splash didnt help me>> still the products are not syncing
There is a thread on the French Dolibarr forum where we also discuss this matter.
I posted 3 instructions to patch prestashoptodolibarrpro PrestaShop module on your own.
I consider forking the project on GitHub to help everybody.
Is there someone interested?
