When I tried to update I get this database error. Any help? Anybody with the same problem?
Error de SQL : DB_ERROR_1406 - INSERT INTO llx_c_actioncomm (id, code, type, libelle, module, active, position) VALUES ( 60,‘AC_EO_ONLINECONF’,‘module’,‘Online/Virtual conference’,‘conference@eventorganization’, 1, 60); - Data too long for column ‘code’ at row 1
Error de SQL : DB_ERROR_1406 - INSERT INTO llx_c_actioncomm (id, code, type, libelle, module, active, position) VALUES ( 61,‘AC_EO_INDOORCONF’,‘module’,‘Indoor conference’,‘conference@eventorganization’, 1, 61); - Data too long for column ‘code’ at row 1
Error de SQL : DB_ERROR_1406 - INSERT INTO llx_c_actioncomm (id, code, type, libelle, module, active, position) VALUES ( 62,‘AC_EO_ONLINEBOOTH’,‘module’,‘Online/Virtual booth’,‘booth@eventorganization’, 1, 62); - Data too long for column ‘code’ at row 1
Error de SQL : DB_ERROR_1406 - INSERT INTO llx_c_actioncomm (id, code, type, libelle, module, active, position) VALUES ( 63,‘AC_EO_INDOORBOOTH’,‘module’,‘Indoor booth’,‘booth@eventorganization’, 1, 63); - Data too long for column ‘code’ at row 1
Error de SQL : DB_ERROR_NOSUCHFIELD - INSERT INTO llx_c_availability (rowid,code,label,active,position) VALUES (1, ‘AV_NOW’, ‘Immediate’, 1, 10); - Unknown column ‘position’ in ‘field list’
Error de SQL : DB_ERROR_NOSUCHFIELD - INSERT INTO llx_c_availability (rowid,code,label,active,position) VALUES (2, ‘AV_1W’, ‘1 week’, 1, 20); - Unknown column ‘position’ in ‘field list’
Error de SQL : DB_ERROR_NOSUCHFIELD - INSERT INTO llx_c_availability (rowid,code,label,active,position) VALUES (3, ‘AV_2W’, ‘2 weeks’, 1, 30); - Unknown column ‘position’ in ‘field list’
Error de SQL : DB_ERROR_NOSUCHFIELD - INSERT INTO llx_c_availability (rowid,code,label,active,position) VALUES (4, ‘AV_3W’, ‘3 weeks’, 1, 40); - Unknown column ‘position’ in ‘field list’
