I’m using Dolibarr 19.0 and having problems creating ODT templates for it.
I can start with an empty ODT, then I get the same error as in the following description.
I will use the template: “template_project.odt” and copy the entire content 1:1 into my ODT “Versuch.odt”.
Now I can use this template for the linked documents in my project and click Create. I then end up back in my project and the ODT was created.
I can delete everything from this document “Versuch.odt” except these 3 tables (see download). As soon as I delete one of these 3 tables, or delete the contents in its 2nd line, the following error occurs. PS: I can safely delete the contents of the first lines, nothing will happen.
If I want to create a document again in my project with my “Template.odt” among the linked documents, I end up on a blank page in the browser. I can’t get back into the project and the document hasn’t been created either.
What is so special about these 3 tables that I cannot delete or edit them? When I create a new empty ODT template, the result always remains with this error. If I insert these 3 tables into my template using copy/paste, then the template I created also works. But I don’t want these 3 tables!
Thanks a lot
Clamsy
