Hello everyone,
As mentioned in the subject, I would like to know if there is a way to ensure that, once a product with variants is created, the variant attributes remain assigned to the product so that I only need to select the values of those attributes.
I ask this because I have many variable products with different attributes (sometimes more than 3 per product), and every time I need to create a new variant, I have to re-select all the variant attributes and their respective values.
Here’s an example:
- I have Product A with variant attributes: color, weight, dimension.
- I have Product B with variant attributes: material, diameter, finish.
Currently, every time I create a new variant, I have to re-select the variant attributes and their values in the same sequence, which is quite inconvenient when dealing with many types of variants. If there was a way to lock the attributes to the product, I would only need to select the values for those attributes to create a new variant, and it would help avoid mistakes.
Is there any plugin that does this?
I’m using Dolibarr Ver. 21.0.1 on a Synology NAS.
Thanks a lot in advance for any replies!
