Is there any automation from project to product.
For example, If the project has been completed can it directly report to the product.
Thank you
Thank you
hi,
I im not sure I follow:
- do you want that project end will create product ? then what is the advantage of automation ?
- does a product sell lead to a project ? then shouldn’t you link the project to the order ? but again what is the added value ? (important to understand the automation)
Bottom line, if you have industrialized tasks for you product maybe project are not the right artefact to use.
br.
