Hi guys
I have a problem about make reception
when i make new purchase order i cant make reception on that while i could do it before
i already checked the reception model and permission and those were ok
can any one help me?
hello again
my problem solved guys ![]()
if anyone have the same problem text me
Hello @NAFAS,
Good that you found the solution ![]()
Can you share it ?
It can help others on this forum.
Thanks.
sure after so much effort i follow these steps and it solved
setup>modules>stocks>enabled Increase real stocks on validation of reception
hope it helps ![]()
