Hi all, hope you can help.
Ive carefully input each batch/lot of raw materials and intermediate component products i have in my inventory.
To create my finished products for sale, i need to be able to trace lot numbers from raw materials to intermediate products to finished product for transparency and potential product recall purposes.
When i try to create a manufacturing order, and click consume or produce, i get a dropdown to select warehouses showing total stock, but the lot/serial area is empty and appears to be manual entry.
I had assumed that i would be able to select quantities to consume per lot number (in the same way you can choose warehouse).
I really hope this is possible! This traceability function is the reason i started using Dolibarr… ![]()
