Templates for Projects? (Module)
Good Morning,
I was wondering if there is any Module that allows to do Templates for Projects (and Tasks).
Reason why I need/want this is that all our Projects are very similar (solar Plant Installation).
So I would like to have different Templates for different sizes of plants because the requirements only change with size.
Since every Plant is almost the same its would be very elaborate to the whole Project/Task setup for every Customer.
If you have any ideas for a Module or how to handle it otherwise please let me know .)
Greetings Dennis
what you need can be achieved quite easily without additional modules: Just create the template project with the respective tasks as a regular project. Name the “Template” or whatever you like to later be able to find it.
Once you need the template for an actual project, just open it and press the button “clone”.
Joachim
Thank you for the fast reply.
I didnt know that tasks would be cloned too together with the project.
I will try this then for now.
