This morning tried to logon to dolibarr and keep getting save file message.
Below is extract of file:
<?php
/* Copyright (C) 2001-2004 Rodolphe Quiedeville <rodolphe@quiedeville.org>
* Copyright (C) 2004-2020 Laurent Destailleur <eldy@users.sourceforge.net>
* Copyright (C) 2005-2017 Regis Houssin <regis.houssin@inodbox.com>
* Copyright (C) 2011-2012 Juanjo Menent <jmenent@2byte.es>
* Copyright (C) 2015 Marcos García <marcosgdf@gmail.com>
* Copyright (C) 2021 Frédéric France <frederic.france@netlogic.fr>
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <https://www.gnu.org/licenses/>.
* \file htdocs/index.php
* \brief Dolibarr home page
define('CSRFCHECK_WITH_TOKEN', 1); // We force need to use a token to login when making a POST
require 'main.inc.php';
require_once DOL_DOCUMENT_ROOT.'/core/class/html.formother.class.php';
// If not defined, we select menu "home"
$_GET['mainmenu'] = GETPOST('mainmenu', 'aZ09') ? GETPOST('mainmenu', 'aZ09') : 'home';
$action = GETPOST('action', 'aZ09');
$hookmanager->initHooks(array('index'));
* Actions
// Check if company name is defined (first install)
if (!isset($conf->global->MAIN_INFO_SOCIETE_NOM) || empty($conf->global->MAIN_INFO_SOCIETE_NOM)) {
header("Location: ".DOL_URL_ROOT."/admin/index.php?mainmenu=home&leftmenu=setup&mesg=setupnotcomplete");
exit;
if (count($conf->modules) <= (empty($conf->global->MAIN_MIN_NB_ENABLED_MODULE_FOR_WARNING) ? 1 : $conf->global->MAIN_MIN_NB_ENABLED_MODULE_FOR_WARNING)) { // If only user module enabled
exit;
if (GETPOST('addbox')) { // Add box (when submit is done from a form when ajax disabled)
require_once DOL_DOCUMENT_ROOT.'/core/class/infobox.class.php';
$zone = GETPOST('areacode', 'int');
$userid = GETPOST('userid', 'int');
$boxorder = GETPOST('boxorder', 'aZ09');
$boxorder .= GETPOST('boxcombo', 'aZ09');
$result = InfoBox::saveboxorder($db, $zone, $boxorder, $userid);
if ($result > 0) {
setEventMessages($langs->trans("BoxAdded"), null);
* View
if (!isset($form) || !is_object($form)) {
$form = new Form($db);
// Title
$title = $langs->trans("HomeArea").' - Dolibarr '.DOL_VERSION;
if (!empty($conf->global->MAIN_APPLICATION_TITLE)) {
$title = $langs->trans("HomeArea").' - '.$conf->global->MAIN_APPLICATION_TITLE;
llxHeader('', $title);
$resultboxes = FormOther::getBoxesArea($user, "0"); // Load $resultboxes (selectboxlist + boxactivated + boxlista + boxlistb)
print load_fiche_titre(' ', $resultboxes['selectboxlist'], '', 0, '', 'titleforhome');
if (!empty($conf->global->MAIN_MOTD)) {
$conf->global->MAIN_MOTD = preg_replace('/<br(\s[\sa-zA-Z_="]*)?\/?>/i', '<br>', $conf->global->MAIN_MOTD);
$substitutionarray = getCommonSubstitutionArray($langs);
complete_substitutions_array($substitutionarray, $langs);
$texttoshow = make_substitutions($conf->global->MAIN_MOTD, $substitutionarray, $langs);
print "\n<!-- Start of welcome text -->\n";
print '<table width="100%" class="notopnoleftnoright"><tr><td>';
print dol_htmlentitiesbr($texttoshow);
print '</td></tr></table><br>';
print "\n<!-- End of welcome text -->\n";
* Show security warnings
// Security warning repertoire install existe (si utilisateur admin)
if ($user->admin && empty($conf->global->MAIN_REMOVE_INSTALL_WARNING)) {
$message = '';
// Check if install lock file is present
$lockfile = DOL_DATA_ROOT.'/install.lock';
if (!empty($lockfile) && !file_exists($lockfile) && is_dir(DOL_DOCUMENT_ROOT."/install")) {
$langs->load("errors");
//if (! empty($message)) $message.='<br>';
$message .= info_admin($langs->trans("WarningLockFileDoesNotExists", DOL_DATA_ROOT).' '.$langs->trans("WarningUntilDirRemoved", DOL_DOCUMENT_ROOT."/install"), 0, 0, '1', 'clearboth');
// Conf files must be in read only mode
if (is_writable($conffile)) {
//$langs->load("other");
$message .= info_admin($langs->transnoentities("WarningConfFileMustBeReadOnly").' '.$langs->trans("WarningUntilDirRemoved", DOL_DOCUMENT_ROOT."/install"), 0, 0, '1', 'clearboth');
if ($message) {
print $message;
//$message.='<br>';
//print info_admin($langs->trans("WarningUntilDirRemoved",DOL_DOCUMENT_ROOT."/install"));
* Dashboard Dolibarr states (statistics)
* Hidden for external users
$boxstatItems = array();
$boxstatFromHook = '';
// Load translation files required by page
$langs->loadLangs(array('commercial', 'bills', 'orders', 'contracts'));
// Dolibarr Working Board with weather
if (empty($conf->global->MAIN_DISABLE_GLOBAL_WORKBOARD)) {
$showweather = (empty($conf->global->MAIN_DISABLE_METEO) || $conf->global->MAIN_DISABLE_METEO == 2) ? 1 : 0;
//Array that contains all WorkboardResponse classes to process them
$dashboardlines = array();
// Do not include sections without management permission
require_once DOL_DOCUMENT_ROOT.'/core/class/workboardresponse.class.php';
// Number of actions to do (late)
if (!empty($conf->agenda->enabled) && $user->rights->agenda->myactions->read) {
include_once DOL_DOCUMENT_ROOT.'/comm/action/class/actioncomm.class.php';
$board = new ActionComm($db);
$dashboardlines[$board->element] = $board->load_board($user);
// Number of project opened
if (!empty($conf->projet->enabled) && $user->rights->projet->lire) {
include_once DOL_DOCUMENT_ROOT.'/projet/class/project.class.php';
$board = new Project($db);
// Number of tasks to do (late)
if (!empty($conf->projet->enabled) && empty($conf->global->PROJECT_HIDE_TASKS) && $user->rights->projet->lire) {
include_once DOL_DOCUMENT_ROOT.'/projet/class/task.class.php';
$board = new Task($db);
// Number of commercial proposals open (expired)
if (!empty($conf->propal->enabled) && $user->rights->propale->lire) {
include_once DOL_DOCUMENT_ROOT.'/comm/propal/class/propal.class.php';
$board = new Propal($db);
$dashboardlines[$board->element.'_opened'] = $board->load_board($user, "opened");
// Number of commercial proposals CLOSED signed (billed)
$dashboardlines[$board->element.'_signed'] = $board->load_board($user, "signed");
if (!empty($conf->supplier_proposal->enabled) && $user->rights->supplier_proposal->lire) {
include_once DOL_DOCUMENT_ROOT.'/supplier_proposal/class/supplier_proposal.class.php';
$board = new SupplierProposal($db);
// Number of customer orders a deal
if (!empty($conf->commande->enabled) && $user->rights->commande->lire) {
include_once DOL_DOCUMENT_ROOT.'/commande/class/commande.class.php';
$board = new Commande($db);
// Number of suppliers orders a deal
if (!empty($conf->supplier_order->enabled) && $user->rights->fournisseur->commande->lire) {
include_once DOL_DOCUMENT_ROOT.'/fourn/class/fournisseur.commande.class.php';
$board = new CommandeFournisseur($db);
$dashboardlines[$board->element.'_awaiting'] = $board->load_board($user, 'awaiting');
// Number of contract / services enabled (delayed)
if (!empty($conf->contrat->enabled) && $user->rights->contrat->lire) {
include_once DOL_DOCUMENT_ROOT.'/contrat/class/contrat.class.php';
$board = new Contrat($db);
$dashboardlines[$board->element.'_inactive'] = $board->load_board($user, "inactive");
// Number of active services (expired)
$dashboardlines[$board->element.'_active'] = $board->load_board($user, "active");
// Number of tickets open
if (!empty($conf->ticket->enabled) && $user->rights->ticket->read) {
include_once DOL_DOCUMENT_ROOT.'/ticket/class/ticket.class.php';
$board = new Ticket($db);
//$dashboardlines[$board->element.'_active'] = $board->load_board($user, "active");
// Number of invoices customers (paid)
if (!empty($conf->facture->enabled) && $user->rights->facture->lire) {
include_once DOL_DOCUMENT_ROOT.'/compta/facture/class/facture.class.php';
$board = new Facture($db);
// Number of supplier invoices (paid)
if (!empty($conf->supplier_invoice->enabled) && !empty($user->rights->fournisseur->facture->lire)) {
include_once DOL_DOCUMENT_ROOT.'/fourn/class/fournisseur.facture.class.php';
$board = new FactureFournisseur($db);
// Number of transactions to conciliate
if (!empty($conf->banque->enabled) && $user->rights->banque->lire && !$user->socid) {
include_once DOL_DOCUMENT_ROOT.'/compta/bank/class/account.class.php';
$board = new Account($db);
$nb = $board->countAccountToReconcile(); // Get nb of account to reconciliate
if ($nb > 0) {
// Number of cheque to send
if (!empty($conf->banque->enabled) && $user->rights->banque->lire && !$user->socid && empty($conf->global->BANK_DISABLE_CHECK_DEPOSIT)) {
include_once DOL_DOCUMENT_ROOT.'/compta/paiement/cheque/class/remisecheque.class.php';
$board = new RemiseCheque($db);
// Number of foundation members
if (!empty($conf->adherent->enabled) && $user->rights->adherent->lire && !$user->socid) {
include_once DOL_DOCUMENT_ROOT.'/adherents/class/adherent.class.php';
$board = new Adherent($db);
$dashboardlines[$board->element.'_shift'] = $board->load_board($user, 'shift');
$dashboardlines[$board->element.'_expired'] = $board->load_board($user, 'expired');
// Number of expense reports to approve
if (!empty($conf->expensereport->enabled) && $user->rights->expensereport->approve) {
include_once DOL_DOCUMENT_ROOT.'/expensereport/class/expensereport.class.php';
$board = new ExpenseReport($db);
$dashboardlines[$board->element.'_toapprove'] = $board->load_board($user, 'toapprove');
// Number of expense reports to pay
if (!empty($conf->expensereport->enabled) && $user->rights->expensereport->to_paid) {
$dashboardlines[$board->element.'_topay'] = $board->load_board($user, 'topay');
// Number of holidays to approve
if (!empty($conf->holiday->enabled) && $user->rights->holiday->approve) {
include_once DOL_DOCUMENT_ROOT.'/holiday/class/holiday.class.php';
$board = new Holiday($db);
$object = new stdClass();
$parameters = array();
$action = '';
$reshook = $hookmanager->executeHooks(
'addOpenElementsDashboardLine',
$parameters,
$object,
$action
); // Note that $action and $object may have been modified by some hooks
if ($reshook == 0) {
$dashboardlines = array_merge($dashboardlines, $hookmanager->resArray);
/* Open object dashboard */
$dashboardgroup = array(
'action' =>
array(
'groupName' => 'Agenda',
'stats' => array('action'),
'project' =>
array(
'groupName' => 'Projects',
'globalStatsKey' => 'projects',
'stats' => array('project', 'project_task'),
'propal' =>
array(
'groupName' => 'Proposals',
'globalStatsKey' => 'proposals',
'stats' =>
array('propal_opened', 'propal_signed'),
'commande' =>
array(
'groupName' => 'Orders',
'globalStatsKey' => 'orders',
'stats' =>
array('commande'),
'facture' =>
array(
'groupName' => 'Invoices',
'globalStatsKey' => 'invoices',
'stats' =>
array('facture'),
'supplier_proposal' =>
array(
'groupName' => 'SupplierProposals',
'globalStatsKey' => 'askprice',
'stats' =>
array('supplier_proposal_opened', 'supplier_proposal_signed'),
'order_supplier' =>
array(
'groupName' => 'SuppliersOrders',
'globalStatsKey' => 'supplier_orders',
'stats' =>
array('order_supplier_opened', 'order_supplier_awaiting'),
'invoice_supplier' =>
array(
'groupName' => 'BillsSuppliers',
'globalStatsKey' => 'supplier_invoices',
'stats' =>
array('invoice_supplier'),
'contrat' =>
array(
'groupName' => 'Contracts',
'globalStatsKey' => 'Contracts',
'stats' =>
array('contrat_inactive', 'contrat_active'),
'ticket' =>
array(
'groupName' => 'Tickets',
'globalStatsKey' => 'ticket',
'stats' =>
array('ticket_opened'),
'bank_account' =>
array(
'groupName' => 'BankAccount',
'stats' =>
array('bank_account', 'chequereceipt'),
'member' =>
array(
'groupName' => 'Members',
'globalStatsKey' => 'members',
'stats' =>
array('member_shift', 'member_expired'),
'expensereport' =>
array(
'groupName' => 'ExpenseReport',
'globalStatsKey' => 'expensereports',
'stats' =>
array('expensereport_toapprove', 'expensereport_topay'),
'holiday' =>
array(
'groupName' => 'Holidays',
'globalStatsKey' => 'holidays',
'stats' =>
array('holiday'),
'dashboardgroup' => $dashboardgroup
$reshook = $hookmanager->executeHooks('addOpenElementsDashboardGroup', $parameters, $object, $action); // Note that $action and $object may have been modified by some hooks
$dashboardgroup = array_merge($dashboardgroup, $hookmanager->resArray);
// Calculate total nb of late
$totallate = $totaltodo = 0;
//Remove any invalid response
//load_board can return an integer if failed or WorkboardResponse if OK
$valid_dashboardlines = array();
foreach ($dashboardlines as $workboardid => $tmp) {
if ($tmp instanceof WorkboardResponse) {
$tmp->id = $workboardid; // Complete the object to add its id into its name
$valid_dashboardlines[$workboardid] = $tmp;
// We calculate $totallate. Must be defined before start of next loop because it is show in first fetch on next loop
foreach ($valid_dashboardlines as $board) {
if ($board->nbtodolate > 0) {
$totaltodo += $board->nbtodo;
$totallate += $board->nbtodolate;
$openedDashBoardSize = 'info-box-sm'; // use sm by default
foreach ($dashboardgroup as $dashbordelement) {
if (is_array($dashbordelement['stats']) && count($dashbordelement['stats']) > 2) {
$openedDashBoardSize = ''; // use default info box size : big
break;
$totalLateNumber = $totallate;
$totallatePercentage = ((!empty($totaltodo)) ? round($totallate / $totaltodo * 100, 2) : 0);
if (!empty($conf->global->MAIN_USE_METEO_WITH_PERCENTAGE)) {
$totallate = $totallatePercentage;
$boxwork = '';
$boxwork .= '<div class="box">';
$boxwork .= '<table summary="'.dol_escape_htmltag($langs->trans("WorkingBoard")).'" class="noborder boxtable boxtablenobottom boxworkingboard centpercent">'."\n";
$boxwork .= '<tr class="liste_titre">';
$boxwork .= '<th class="liste_titre"><div class="inline-block valignmiddle">'.$langs->trans("DolibarrWorkBoard").'</div>';
if ($showweather) {
if ($totallate > 0) {
$text = $langs->transnoentitiesnoconv("WarningYouHaveAtLeastOneTaskLate").' ('.$langs->transnoentitiesnoconv(
"NActionsLate",
$totallate.(!empty($conf->global->MAIN_USE_METEO_WITH_PERCENTAGE) ? '%' : '')
} else {
$text = $langs->transnoentitiesnoconv("NoItemLate");
$text .= '. '.$langs->transnoentitiesnoconv("LateDesc");
//$text.=$form->textwithpicto('',$langs->trans("LateDesc"));
$options = 'height="24px" style="float: right"';
$boxwork .= showWeather($totallate, $text, $options, 'inline-block valignmiddle');
$boxwork .= '</th>';
$boxwork .= '</tr>'."\n";
// Show dashboard
$nbworkboardempty = 0;
$isIntopOpenedDashBoard = $globalStatInTopOpenedDashBoard = array();
if (!empty($valid_dashboardlines)) {
$openedDashBoard = '';
$boxwork .= '<tr class="nobottom nohover"><td class="tdboxstats nohover flexcontainer centpercent"><div style="display: flex: flex-wrap: wrap">';
foreach ($dashboardgroup as $groupKey => $groupElement) {
$boards = array();
if (empty($conf->global->MAIN_DISABLE_NEW_OPENED_DASH_BOARD)) {
foreach ($groupElement['stats'] as $infoKey) {
if (!empty($valid_dashboardlines[$infoKey])) {
$boards[] = $valid_dashboardlines[$infoKey];
$isIntopOpenedDashBoard[] = $infoKey;
if (!empty($boards)) {
$groupName = $langs->trans($groupElement['groupName']);
$groupKeyLowerCase = strtolower($groupKey);
$nbTotalForGroup = 0;
// global stats
$globalStatsKey = false;
if (!empty($groupElement['globalStatsKey']) && empty($groupElement['globalStats'])) { // can be filled by hook
$globalStatsKey = $groupElement['globalStatsKey'];
$groupElement['globalStats'] = array();
if (isset($keys) && is_array($keys) && in_array($globalStatsKey, $keys)) {
// get key index of stats used in $includes, $classes, $keys, $icons, $titres, $links
$keyIndex = array_search($globalStatsKey, $keys);
$classe = (!empty($classes[$keyIndex]) ? $classes[$keyIndex] : '');
if (isset($boardloaded[$classe]) && is_object($boardloaded[$classe])) {
$groupElement['globalStats']['total'] = $boardloaded[$classe]->nb[$globalStatsKey] ? $boardloaded[$classe]->nb[$globalStatsKey] : 0;
$nbTotal = floatval($groupElement['globalStats']['total']);
if ($nbTotal >= 10000) {
$nbTotal = round($nbTotal / 1000, 2).'k';
$groupElement['globalStats']['text'] = $langs->trans('Total').' : '.$langs->trans($titres[$keyIndex]).' ('.$groupElement['globalStats']['total'].')';
$groupElement['globalStats']['total'] = $nbTotal;
$groupElement['globalStats']['link'] = $links[$keyIndex];
$openedDashBoard .= '<div class="box-flex-item"><div class="box-flex-item-with-margin">'."\n";
$openedDashBoard .= ' <div class="info-box '.$openedDashBoardSize.'">'."\n";
$openedDashBoard .= ' <span class="info-box-icon bg-infobox-'.$groupKeyLowerCase.'">'."\n";
$openedDashBoard .= ' <i class="fa fa-dol-'.$groupKeyLowerCase.'"></i>'."\n";
// Show the span for the total of record
if (!empty($groupElement['globalStats'])) {
$globalStatInTopOpenedDashBoard[] = $globalStatsKey;
$openedDashBoard .= '<span class="info-box-icon-text" title="'.$groupElement['globalStats']['text'].'">'.$nbTotal.'</span>';
$openedDashBoard .= '</span>'."\n";
$openedDashBoard .= '<div class="info-box-content">'."\n";
$openedDashBoard .= '<div class="info-box-title" title="'.strip_tags($groupName).'">'.$groupName.'</div>'."\n";
$openedDashBoard .= '<div class="info-box-lines">'."\n";
foreach ($boards as $board) {
$openedDashBoard .= '<div class="info-box-line">';
if (!empty($board->labelShort)) {
$infoName = '<span title="'.$board->label.'">'.$board->labelShort.'</span>';
} else {
$infoName = $board->label;
$textLateTitle = $langs->trans("NActionsLate", $board->nbtodolate);
$textLateTitle .= ' ('.$langs->trans("Late").' = '.$langs->trans("DateReference").' > '.$langs->trans("DateToday").' '.(ceil($board->warning_delay) >= 0 ? '+' : '').ceil($board->warning_delay).' '.$langs->trans("days").')';
if ($board->id == 'bank_account') {
$textLateTitle .= '<br><span class="opacitymedium">'.$langs->trans("IfYouDontReconcileDisableProperty", $langs->transnoentitiesnoconv("Conciliable")).'</span>';
$textLate = '';
$textLate .= '<span title="'.dol_escape_htmltag($textLateTitle).'" class="classfortooltip badge badge-warning">';
$textLate .= '<i class="fa fa-exclamation-triangle"></i> '.$board->nbtodolate;
$textLate .= '</span>';
$nbtodClass = '';
if ($board->nbtodo > 0) {
$nbtodClass = 'badge badge-info';
$openedDashBoard .= ' <a href="'.$board->url.'" class="info-box-text info-box-text-a">'.$infoName.' : <span class="'.$nbtodClass.' classfortooltip" title="'.$board->label.'" >'.$board->nbtodo.'</span>';
if ($textLate) {
if ($board->url_late) {
$openedDashBoard .= '</a>';
$openedDashBoard .= ' <a href="'.$board->url_late.'" class="info-box-text info-box-text-a paddingleft">';
} else {
$openedDashBoard .= ' ';
$openedDashBoard .= $textLate;
$openedDashBoard .= '</a>'."\n";
if ($board->total > 0 && !empty($conf->global->MAIN_WORKBOARD_SHOW_TOTAL_WO_TAX)) {
$openedDashBoard .= '<a href="'.$board->url.'" class="info-box-text">'.$langs->trans('Total').' : '.price($board->total).'</a>';
$openedDashBoard .= '</div>'."\n";
// TODO Add hook here to add more "info-box-line"
$openedDashBoard .= ' </div><!-- /.info-box-lines --></div><!-- /.info-box-content -->'."\n";
$openedDashBoard .= ' </div><!-- /.info-box -->'."\n";
$openedDashBoard .= '</div><!-- /.box-flex-item-with-margin -->'."\n";
$openedDashBoard .= '</div><!-- /.box-flex-item -->'."\n";
$openedDashBoard .= "\n";
if ($showweather && !empty($isIntopOpenedDashBoard)) {
$appendClass = (!empty($conf->global->MAIN_DISABLE_METEO) && $conf->global->MAIN_DISABLE_METEO == 2 ? ' hideonsmartphone' : '');
$weather = getWeatherStatus($totallate);
$text = '';
"NActionsLate",
} else {
$weatherDashBoard = '<div class="box-flex-item '.$appendClass.'"><div class="box-flex-item-with-margin">'."\n";
$weatherDashBoard .= ' <div class="info-box '.$openedDashBoardSize.' info-box-weather info-box-weather-level'.$weather->level.'">'."\n";
$weatherDashBoard .= ' <span class="info-box-icon">';
$weatherDashBoard .= img_weather('', $weather->level, '', 0, 'valignmiddle width50');
$weatherDashBoard .= ' </span>'."\n";
$weatherDashBoard .= ' <div class="info-box-content">'."\n";
$weatherDashBoard .= ' <div class="info-box-title">'.$langs->trans('GlobalOpenedElemView').'</div>'."\n";
if ($totallatePercentage > 0 && !empty($conf->global->MAIN_USE_METEO_WITH_PERCENTAGE)) {
$weatherDashBoard .= ' <span class="info-box-number">'.$langs->transnoentitiesnoconv(
"NActionsLate",
price($totallatePercentage).'%'
).'</span>'."\n";
$weatherDashBoard .= ' <span class="progress-description">'.$langs->trans(
'NActionsLate',
$totalLateNumber
).'</span>'."\n";
} else {
"NActionsLate",
$totalLateNumber
).'</span>'."\n";
if ($totallatePercentage > 0) {
'NActionsLate',
).'</span>'."\n";
$weatherDashBoard .= ' </div><!-- /.info-box-content -->'."\n";
$weatherDashBoard .= ' </div><!-- /.info-box -->'."\n";
$weatherDashBoard .= '</div><!-- /.box-flex-item-with-margin -->'."\n";
$weatherDashBoard .= '</div><!-- /.box-flex-item -->'."\n";
$weatherDashBoard .= "\n";
$openedDashBoard = $weatherDashBoard.$openedDashBoard;
if (!empty($isIntopOpenedDashBoard)) {
for ($i = 1; $i <= 10; $i++) {
$openedDashBoard .= '<div class="box-flex-item filler"></div>';
$nbworkboardcount = 0;
foreach ($valid_dashboardlines as $infoKey => $board) {
if (in_array($infoKey, $isIntopOpenedDashBoard)) {
// skip if info is present on top
continue;
if (empty($board->nbtodo)) {
$nbworkboardempty++;
$nbworkboardcount++;
$textlate = $langs->trans("NActionsLate", $board->nbtodolate);
$textlate .= ' ('.$langs->trans("Late").' = '.$langs->trans("DateReference").' > '.$langs->trans("DateToday").' '.(ceil($board->warning_delay) >= 0 ? '+' : '').ceil($board->warning_delay).' '.$langs->trans("days").')';
$boxwork .= '<div class="boxstatsindicator thumbstat150 nobold nounderline"><div class="boxstats130 boxstatsborder">';
$boxwork .= '<div class="boxstatscontent">';
$boxwork .= '<span class="boxstatstext" title="'.dol_escape_htmltag($board->label).'">'.$board->img.' <span>'.$board->label.'</span></span><br>';
$boxwork .= '<a class="valignmiddle dashboardlineindicator" href="'.$board->url.'"><span class="dashboardlineindicator'.(($board->nbtodo == 0) ? ' dashboardlineok' : '').'">'.$board->nbtodo.'</span></a>';
$boxwork .= ' / <a class="valignmiddle dashboardlineindicator" href="'.$board->url.'"><span class="dashboardlineindicator'.(($board->nbtodo == 0) ? ' dashboardlineok' : '').'">'.price($board->total).'</span></a>';
$boxwork .= '</div>';
$boxwork .= '<div class="dashboardlinelatecoin nowrap">';
$boxwork .= '<a title="'.dol_escape_htmltag($textlate).'" class="valignmiddle dashboardlineindicatorlate'.($board->nbtodolate > 0 ? ' dashboardlineko' : ' dashboardlineok').'" href="'.((!$board->url_late) ? $board->url : $board->url_late).'">';
//$boxwork .= img_picto($textlate, "warning_white", 'class="valigntextbottom"').'';
$textlate,
"warning_white",
'class="inline-block hideonsmartphone valigntextbottom"'
$boxwork .= '<span class="dashboardlineindicatorlate'.($board->nbtodolate > 0 ? ' dashboardlineko' : ' dashboardlineok').'">';
$boxwork .= $board->nbtodolate;
$boxwork .= '</span>';
$boxwork .= '</a>';
$boxwork .= '</div></div>';
$boxwork .= "\n";
$boxwork .= '<div class="boxstatsindicator thumbstat150 nobold nounderline"><div class="boxstats150empty"></div></div>';
$boxwork .= '</td></tr>';
} else {
$boxwork .= '<tr class="nohover">';
$boxwork .= '<td class="nohover valignmiddle opacitymedium">';
$boxwork .= $langs->trans("NoOpenedElementToProcess");
$boxwork .= '</td>';
$boxwork .= '</tr>';
$boxwork .= '</table>'; // End table array of working board
print '<div class="fichecenter">';
print '<div class="opened-dash-board-wrap"><div class="box-flex-container">'.$openedDashBoard.'</div></div>';
print '</div>';
print '<div class="clearboth"></div>';
print '<div class="fichecenter fichecenterbis">';
* Show widgets (boxes)
$boxlist = '<div class="twocolumns">';
$boxlist .= '<div class="firstcolumn fichehalfleft boxhalfleft" id="boxhalfleft">';
if (!empty($nbworkboardcount)) {
$boxlist .= $boxwork;
$boxlist .= $resultboxes['boxlista'];
$boxlist .= '</div>';
$boxlist .= '<div class="secondcolumn fichehalfright boxhalfright" id="boxhalfright">';
$boxlist .= $resultboxes['boxlistb'];
$boxlist .= "\n";
print $boxlist;
print '</div>';
//print 'mem='.memory_get_usage().' - '.memory_get_peak_usage();
// End of page
llxFooter();
$db->close();
* Show weather logo. Logo to show depends on $totallate and values for
* $conf->global->MAIN_METEO_LEVELx
* @param int $totallate Nb of element late
* @param string $text Text to show on logo
* @param string $options More parameters on img tag
* @param string $morecss More CSS
* @return string Return img tag of weather
function showWeather($totallate, $text, $options, $morecss = '')
global $conf;
return img_weather($text, $weather->picto, $options, 0, $morecss);
* get weather level
* @return stdClass Return img tag of weather
function getWeatherStatus($totallate)
global $conf;
$weather = new stdClass();
$weather->picto = '';
$offset = 0;
$factor = 10; // By default
$used_conf = empty($conf->global->MAIN_USE_METEO_WITH_PERCENTAGE) ? 'MAIN_METEO_LEVEL' : 'MAIN_METEO_PERCENTAGE_LEVEL';
$level0 = $offset;
$weather->level = 0;
if (!empty($conf->global->{$used_conf.'0'})) {
$level0 = $conf->global->{$used_conf.'0'};
$level1 = $offset + 1 * $factor;
if (!empty($conf->global->{$used_conf.'1'})) {
$level1 = $conf->global->{$used_conf.'1'};
$level2 = $offset + 2 * $factor;
if (!empty($conf->global->{$used_conf.'2'})) {
$level2 = $conf->global->{$used_conf.'2'};
$level3 = $offset + 3 * $factor;
if (!empty($conf->global->{$used_conf.'3'})) {
$level3 = $conf->global->{$used_conf.'3'};
if ($totallate <= $level0) {
$weather->picto = 'weather-clear.png';
} elseif ($totallate <= $level1) {
$weather->picto = 'weather-few-clouds.png';
$weather->level = 1;
} elseif ($totallate <= $level2) {
$weather->picto = 'weather-clouds.png';
$weather->level = 2;
} elseif ($totallate <= $level3) {
$weather->picto = 'weather-many-clouds.png';
$weather->level = 3;
} else {
$weather->picto = 'weather-storm.png';
$weather->level = 4;
return $weather;
