I have a spreadsheet with all the products I wish to import in cdv or excel format, using dolibar13 when I use the import module the available formats is not populated.
I am not clear of how to populate these formats, the documentation shows
File import must have one of the following formats
CSV
Excel 2007
These do not show in my system how do I create formats?
I can not see a line “$dolibarr_lib_PHPEXCEL_PATH=‘disabled’;” to comment it out so I assume this is not the solution, if phpexcel module is depreciated does this mean I have to somehow install the phpspreadsheet and then tell dolibar to use that. I am using Centos 7 with Dolibar 13
I have 900 products to enter, we could do this manually I suppose.
Hello brittain,
Did you find a solution, because I face a similar problem?
Export assistant shows all formats CSV, Excel 2007 and TSV, but Import Assistant nothing?
