Hi everyone,
for a simple way of organising ingoing and outgoing products out of the warehouse i would like to use the in build functions of dolibarr combined with the qr code functions.
An example:
http://“ip”/dolibarr/product/stock/product.php?id=00010
Im using this link as the qr code so that when i scan it with my smartphone i am directly forwarded to the warehouse functions for the product with the id=10.
This works fine.
Now i would like dolibarr to automatically generate this link with the right id.
Ive tried to use this as the autogenerator format:
http://“id”/dolibarr/product/stock/product.php?id={00000}
Unfortunately the barcode numerating and the product ids does not sync good. for the first like 20 products it works fine but then it doenst sync anymore. I think the id is incremented anywhere else aswell.
Is it possible to use something like {$id} instead of {00000} ?
Kind regards,
NBecker
