v3.5.1
Fix: Do not report trigger errors twice.
Fix: Error when creating event was not reported.
Fix: Bug of import of agenda when using https link
Fix: Field nature not saved correctly
Fix: Substitution of extra field was ko for order
Fix: Bad translation of date format for pt_BR.
Fix: priority field of agenda record is smallint.
Fix: Missing loading of lang in some pages.
Fix: Write note in invoice when using pos module.
Fix: Link to paypal was invalid into email text.
Fix: ref and date of supplier invoice.
Fix: Check on bank account.
Fix: Problem with file upload and download.
Fix: Page load not ending when large number of thirdparties. We
added option MAIN_DISABLE_AJAX_COMBOX to disable javascript
combo feature that is root cause of problem.
Fix: [ bug #1231 ] PDF always generated in interventions
Fix: Be sure there is no duplicate default rib.
Fix: Enable extrafields for customer order, proposal and invoice lines. This feature
was developed for 3.5 but was disabled (hidden) because of a bug not possible to
fix enough quickly for 3.5.0 release.
Fix: user right on Holiday for month report nor working.
Fix: [ bug #1250 ] "Supplier Ref. product" sidebar search box does not work
Fix: Bad space in predefined messages.
Fix: [ bug #1256 ] Signature was not added for email sent from thirdparty page.
Fix: Action event SHIPPING_VALIDATE is not implemented
Fix: The customer code was set to uppercase when using numbering module leopard. We
must keep data safe of any change.
Fix: [ bug #1291 ] Loading actions extrafields fails.
Fix: [ bug #1123 ] Paid deposit invoices are always shown as partially paid when fully paid
Fix: Corrected project contact types translation.
Fix: [ bug #1206 ] PMP price is bad calculated.
Fix: [ bug #520 ] Product statistics and detailed lists are wrong.
Fix: [ bug #1240 ] traduction.
Fix: [ bug #1238 ] When creating accompte with a %, free product are used for calculation.
Fix: [ bug #1280 ] service with not end of date was tagged as expired.
Fix: [ bug #1295 ] Error when creating an agenda extrafield with a number as reference.
Fix: [ bug #1306 ] Fatal error when adding an external calendar.
New: Added es_CL language
Fix: Margin tabs bad data show
Fix: [ bug #1318 ] Problem with enter key when adding an existing product to a customer invoice.
Fix: [ bug #1410 ] Add customer order line asks for required Unit Price but doesn't interrupt the creation of the line
v3.5.2
Fix: Can't add user for a task.
Fix: Autoselect of warehouse if there is only one warehouse.
Fix: Install of odt template for project and tasks.
Fix: [ bug #1307 ] Quotes get removed from several inputs.
Fix: [ bug #1317 ] Removing a category does not remove all child categories
Fix: [ bug #1312 ] Call to undefined function _()
Fix: Restore build for obs and launchpad.
Fix: deleting files into backup system tools.
Fix: Dump using php not not include lock on tables that are deleted.
Fix: Fixed a problem with bank accounts sharing across entities.
Fix: fields into group by of sql requests for module margins must be
same than fields into select.
Fix: When select_date is called with '' as preselected date,
automatic user date was not correctly et (We must set a date into PHP
server timezone area)
Fix: First param of select_date must always be forged with a dolibarr
date function and not time().
Fix: fix can't add line with product in supplier order
Fix: [bug #1309]
Fix: Solve pb of too many embedded tables
Fix: A fix to manage automatic creation of code for import.
Fix: Try to add code to provide easy way to fix warning on timezone not
defined.
Fix: Several fix into workflow/condition for invoice payments or convert
into discount.
Fix: Option MAIN_PDF_DASH_BETWEEN_LINES was not working when tcpdf was
making a pagebreak higher than 2 pages.
Fix: form to add images should not show link form.
Fix: Correction when adding order line with price as '0'.
Fix: [ bug #1283 ] ROUGET Shipment PDF.
Fix: [ bug #1300 ]
Fix: Miscellaneous problems on task tabs (withproject parameter lost and
download fails).
Fix: Avoid home project page to hung when too many tasks opened.
Fix: bug #1295: Error when creating an agenda extrafield with a number as reference
Fix: Translation of number for pt_PT.
Fix: Error on ajax_constantonoff function.
Fix: [ bug #1323 ] problème pour générer un odt depuis les taches dans projet.
Fix: Can not make withdrawals
v3.5.3
Fix: Error on field accountancy code for export profile of invoices.
Fix: [ bug #1351 ] VIES verification link broken.
Fix: [ bug #1352 ] Removing a shipping does not remove the delivery.
Fix: Option MAIN_INVERT_SENDER_RECIPIENT broken with typhon template.
Fix: Can disable features with PHPEXCEL (no DLSF compatible).
Fix: Can disable features with CKEDITOR.
Fix: Pb of records not correctly cleaned when module marge is
uninstalled (conflict between 'margin' and 'margins').
Fix: [ bug #1341 ] Lastname not added by file or direct input in mass e-mailing.
Fix: [ bug #1357 ] Invoice creator state not printed in generated invoice documents.
Fix: Suppliers invoice mask fails using {tttt} in numbering.
Fix: [ bug #1350 ] pdf template name for typhon was not correctly set when enabling module.
Fix: Navigation on notes for shipments was not working.
Fix: [ bug #1353 ] Email notifications, wrong URL.
Fix: [ bug #1362 ] Note is not saved.
Fix: tr/td balance.
Fix: [ bug #1360 ] note indicator for member tab.
Fix: Nb of notes and doc not visible onto tasks.
Fix: [ bug #1372 ] Margin calculation does not work in proposals.
Fix: [ bug #1381 ] PHP Warning when listing stock transactions page.
Fix: [ bug #1367 ] "Show invoice" link after a POS sell throws an error.
Fix: TCPDF error file not found in member card generation.
Fix: [ bug #1380 ] Customer invoices are not grouped in company results report.
Fix: [ bug #1393 ] PHP Warning when creating a supplier invoice.
Fix: [ bug #1399 ] [pgsql] Silent warning when setting a propal as "facturée" in propal.php
Fix: When number reach 9999 with default numbering module, next number
will be 10000 instead of 0000 and error.
Fix: element page on project give wrong href link.
Fix: [ bug #1397 ] Filter by supplier orders with status Draft does not filter.
Fix: [ bug #1388 ] Wrong date when invoicing several orders.
Fix: [ bug #1411 ] Unable to set an expedition note if invoices module is not enabled.
Fix: [ bug #1407 ] Rouget pdf overlapped when using tracking number and public notes.
Fix: [ bug #1405 ] Rouget PDF expedition incorrect when two expeditions under the same commande
Fix: [ bug #1434 ] Muscadet supplier order document model linked objects overlap the text
v3.5.4
Fix: Hide title of event when agenda module disabled.
Fix: When using option MAIN_MAIL_ALLOW_SENDMAIL_F, a mail was sent to sender.
Fix: Question about warehouse must not be done when module stock is disabled.
Fix: Option STOCK_SUPPORTS_SERVICES was not correctly implemented
(missing test at some places).
Fix: Renaming a project with uploaded files failed.
Fix: [ bug #1476 ] Invoice creation form loses invoice date when there is a validation error.
Fix: [ bug #1431 ] Reception and Send supplier order box has a weird top margin.
Fix: [ bug #1428 ] "Nothing" is shown in the middle of the screen in a supplier order.
Fix: The object deliverycompany was not used anymore and output of
details for delivery reports was lost during 3.5. Rewrite code to
restore feature.
Fix: [ bug #1445 ] html fix : missing </tr>
Fix: [ bug #1415 ] Intervention document model name and suppliers model names is not shown
properly in module configuration
Fix: [ bug #1416 ] Supplier order does not list document models in the select box of the
supplier order card
Fix: [ bug #1443 ] Payment conditions is erased after editing supplier invoice label or
limit date for payment
Fix: Filter on status was not visible when selected from url.
Fix: Filtering on status was last when asking to sort.
Fix: [ bug #1432 ] Trigger SHIPPING_CREATE ignores interception on error.
Fix: [ bug #1449 ] Trigger ORDER_CREATE, LINEORDER_DELETE, LINEORDER_UPDATE and LINEORDER_INSERT ignore interception on error.
Fix: [ bug #1450 ] Several Customer order's triggers do not report the error from the trigger handler.
Fix: [ bug #1451 ] Interrupted order clone through trigger, loads nonexistent order.
Fix: [ bug #1454 ] Mention de bas de page erroné
Fix: Do not display dictionary for non activated module
Fix: Link element from element project pages
Fix: [ bug #1509 ] Expedition admin free text & watermark submit error
Fix: [ bug #1349 ] AJAX contact selector does not work fine in Project card
Fix: [ bug #1452 ] variable used but not defined
Fix: If multiprice level is used the VAT on addline is not correct
Fix: [ bug #1254 ] Error when using "Enter" on qty input box of a product (on supplier order part)
Fix: [ bug #1462, 1468, 1480, 1483, 1490, 1497] $this instead of $object
Fix: [ bug #1455 ] outstanding amount
Fix: [ bug #1425 ] LINEBILL_SUPPLIER_DELETE failure trigger leads to an endless loop
Fix: [ bug #1460 ] Several supplier order triggers do not show error messages
Fix: [ bug #1461 ] LINEORDER_SUPPLIER_CREATE does not intercept supplier order line insertion
Fix: [ bug #1484 ] BILL_SUPPLIER_PAYED trigger action does not intercept failure under some circumstances
Fix: [ bug #1482 ] Several supplier invoice triggers do not show trigger error messages
Fix: [ bug #1486 ] LINEBILL_SUPPLIER_CREATE and LINEBILL_SUPPLIER_UPDATE triggers do not intercept trigger action
Fix: [ bug #1522 ] Element list into associate object into project are no more filterd by project thirdparty
Fix: [ bug #1526 ] Thumbs of files uploaded with dots in their names do not load correctly
Fix: Import ProfId1 to siren and ProfId2 to siret
v3.5.5
Fix: Holiday module was broken. Initialization of amount of holidays failed.
Fix: [ bug #1523 ] suite bug #1334 : filtre et ordre de tri conjoints ne s'appliquent pas.
Fix: Fusion PDF button on unpaid invoice is no more displayed.
Fix: Unpaid invoice launch fusion PDF action even if it is only search (with enter keyboard input instead of lens click).
Fix: Pb when showing log list of holiday module with some mysql versions.
Fix: Error with bad timezone pushed by some browsers.
Fix: shipping list SQL request was not filtering on shipping element
Fix: debian package provided by dolibarr team must use embedded libraries.
Fix: [ bug #1528 ] Leopard Services numeration module description is not translated.
Fix: [ bug #1534 ] Unknown error when deleting a product photo under special circumstances.
Fix: Update impayees.php
Fix: Link product, In list view and label product.
Fix: visible task into area "time" for "My task" must limit task to tasks i am assigned to.
Fix: When disabled, all fields to add time into task line must be disabled.
Fix: Missing include files.lib.php in some pages that use dol_delete_recursive
Fix: [ bug #1558 ] Product/service edit page title shows new Ref instead of old ref.
Fix: [ bug #1553 ] Saving User displays setup removes menu.
Fix: [ bug #1544 ] Can remove date from invoice.
Fix: list event view lost type event filter.
Fix: Add code save on create event.
Fix: SQL injection.
Fix: [ bug #1589 ] Menu type in "Edit menu" page is not translated
Fix: [ bug #1591 ] Linked object block shows Total HT/TTC even if not having permission to read them
Fix: [ bug #1577 ] When creating new Private individual third, selected third type is ignored
Fix: [ bug #1555 ] Update accountancy code of products does not throw PRODUCT_MODIFY trigger
Fix: [ bug #1548 ] Supplier payment card shows type in French
Fix: [ bug #1546 ] Incorrect page number when searching in the list of bank transactions
v3.5.6
Fix: Avoid missing class error for fetch_thirdparty method #1973
Fix: Can't update phone_pro from web service
Fix: Some security holes.
Fix: copy extrafields when creating order from proposal.
Fix: report on action was not filtering by environment.
Fix: Avoid missing class error.
Fix: Add function dolEscapeXML.
Fix: Bad days and month reported by function.
Fix: Bad margin calculation.
v3.5.7
Fix: Paypal link were broken due to SSL v3 closed.
Fix: [ bug #1769 ] Error when installing to a PostgreSQL DB that contains numbers
Fix: [ bug #1752 ] Date filter of margins module, filters since 12H instead of 00H
Fix: [ bug #1757 ] Sorting breaks product/service statistics
Fix: [ bug #1797 ] Tulip supplier invoice module takes creation date instead of invoice date
Fix: [ bug #1792 ] Users are not allowed to see margins module index page when no product view permission is enabled
Fix: [ bug #1846 ] Browser IE11 not detected
Fix: [ bug #1906 ] Deplacement does not allow translated decimal format
Fix: [ bug #1905 ] Custom deplacement types do not get translated in deplacement card
Fix: [ bug #2583 ] Unable to create a bank transfer with localized numbers
Fix: [ bug #2577 ] Incorrect invoice status in "Linked objects" page of a project
Fix: [ bug #2576 ] Unable to edit a dictionary entry that has # in its ref
Fix: [ bug #2758 ] Product::update sets product note to "null" when $prod->note is null
Fix: [ bug #2757 ] Deleting product category photo gives "Forbidden access" error
Fix: [ bug #2976 ] "Report" tab is the current tab but it is not marked as selected by the UI
Fix: [ bug #2861 ] Undefined variable $res when migrating
Fix: [ bug #2837 ] Product list table column header does not match column body
Fix: [ bug #2835 ] Customer prices of a product shows incorrect history order
Fix: [ bug #2814 ] JPEG photos are not displayed in Product photos page
Fix: [ bug #2715 ] Statistics page has broken layout with long thirdparty names
Fix: [ bug #2570 ] [Contacts] Page should not process if ID is invalid
Fix: [ bug #3268 ] SQL error when accessing thirdparty log page without a socid parameter
Fix: [ bug #3180 ] formObjectOptions hook when editing thirdparty card does not print result
Fix: [ bug #1791 ] Margin menu not available if any Finance module is not enabled
Fix: [ bug #3310 ] OrderLine::fetch, FactureLigne::fetch and PropaleLigne::fetch do not return anything
Fix: [ bug #3206 ] PropaleLigne, OrderLine and FactureLigne given to triggers through update function does not contain all the information
Fix: [ bug #3313 ] Error enabling module with PostgreSQL database
v3.5.8
FIX: #4291 Correctly filter external calendar GETPOSTs
FIX: bad calculation for stock value
FIX: bad stock valo
FIX: change order date on clone (as everywhere else)
FIX: CVE CVE-2015-8685
FIX: The hours of date filter aren't correct
FIX: #3442 Remove useless syslog
FIX: #3448 Pass expected date format
FIX: #3471 3.5 Rounding issue when dispatching non-integer
v3.6.0
For users:
- New: Update ckeditor to version 4.
- New: Add form "search customer order" on commercial main page.
- New: Can create contract from an order.
- New: Add list of orders products in tab "consumption" on thirdparties.
- New: Add graph stats for suppliers orders in tab "stats" on products.
- New: Add option MAIN_HIDE_INACTIVETAB_ON_PRINT to hide inactive tabs when you
use the "print" view on screen.
- New: Add option MAIN_AUTO_TIMESTAMP_IN_PUBLIC_NOTES and MAIN_AUTO_TIMESTAMP_IN_PRIVATE_NOTES
to automatically add timestamp and user line into edition field when editing a note.
- New: Add button cancel into edition of notes.
- New: Improved Barcode module:
Can input barcode during product creation step.
Add autonumbering of barcode value for products.
Add a page/tool for mass barcode generation.
- New: Improved Opensurvey module:
Added options to disable comments and disable public votes.
Limit dates use calendar popup.
Description of survey use wysiwyg editor.
More information shown on result tab.
Renamed "survey" into "poll" (better translation).
- New: Add filter on text and status into survey list. Can also sort on id, text and date end.
- New: The box "balance of bank accounts" show all opened accounts.
- New: Add option MAIN_ADD_SALE_REP_SIGNATURE_IN_NOTE to add sale representative into public
note of generated documents.
- New: Add warning if supplier payment is higher that due amount.
- New: Increase length of url into bookmark module.
- New: Automatic events sending mails add info about linked objects into email content.
- New: Price management enhancement (multiprice level, price by customer, if MAIN_FEATURES_LEVEL=2 Price by qty).
- New: Add option MAIN_FAVICON_URL.
- New: Created {line_price_ht_locale}, {line_price_vat_locale} and {line_price_ttc_locale} ODT tags.
- New: Add filter on project status into task list. By default, only "opened" project are visible.
- New: Status "validated" for project are renamed into "opened".
- New: Add barcode fields into user database.
- New: Add manager name (ceo, director, president...) into main company information page.
- New: Add field url as product properties.
- New: More options to create a credit note (can be filled automatically according to remain to pay).
- New: Can define custom fields for categories.
- New: Prepare generation of SEPA files into module withdrawal.
- New: [ task #1164 ] Add "Ref. supplier" search box in supplier orders
- New: [ task #1345 ] Can filter on status for supplier order.
- New: Add option FACTURE_SENDBYEMAIL_FOR_ALL_STATUS to allow to send invoice by email
whatever is its status.
- New: Add filter date in bank writing list page.
- New: Extrafields can be used as substitution key %EXTRA_XXX% into emails texts for members.
- New: Add categories translation.
- New: Enable option "clone target emailing".
- New: Improved tax module: Add specific page for salaries payment
- New: Add composer.json file so Dolibarr can be publish onto packagist.org.
- New: The combo list of juridical status is now sorted
- New: [ task #926 ] Add extrafield feature on order lines.
- New: [ task #927 ] Add extrafield feature on Proposal lines.
- New: [ task #928 ] Add extrafield feature on invoice lines.
- New: Paypal/paybox email sent after backcall of a payment is now a formatted and translated
HTML content. For member subscription renewal, there is also a link to member.
- New: When a subscription is recorded with invoice and payment:
- the document (PDF) of invoice is also generated.
- the invoice is set to status paid.
- New: Can enter holiday for someone else if user has permission for.
- Fix: Project Task numbering customs rule works.
- Fix: Add actions events not implemented.
- Fix: Price min of composition is not supplier price min by quantity.
- Fix: [ bug #1356 ] Bank accountancy number is limited to 8 numbers.
- Fix: [ bug #1439 ] impossible to remove a a translation (multilanguage-feature)
- New: If multilangue is enabled, mail (from propal, invoice, etc...) message is pre-defaulted in Customer language
- Fix: [ bug #1459 ] _ADD_CONTACT and _DEL_CONTACT triggers do not intercept insertion when reported an error
- Fix: [ bug #1478 ] BILL_PAYED trigger action does not intercept failure under some circumstances
- Fix: [ bug #1479 ] Several customer invoice triggers do not intercept trigger action
- Fix: [ bug #1477 ] Several customer invoice triggers do not show trigger error messages
- Fix: [ bug #1471 ] Several PHP warnings when intercepting USER_CREATE trigger.
- Fix: [ bug #1517 ] Packages sizes.
- Fix: [ bug #1521 ] The second order's page from a provider shows all orders
For translators:
- Update language files.
For developers:
- New: Add path file of trigger into admin trigger list page.
- New: More phpunit tests.
- New: Payments and supplier payment pages tabs can now be extended from modules.
- New: Add option 'aZ' into GETPOST function to check parameters contains
only a to z or A to Z characters.
- New: Opensurvey polls tab cards can now be extended from external modules.
- New: Triggers OPENSURVEY_CREATE, OPENSURVEY_DELETE added.
- New: Add new hook function addMoreActionsButtons to allow a module to add/replace
action buttons into an element.
- New: Normalize code for barcode generation to match other modules.
- New: Uniformize code for contacts forms.
- New: Add some hooks for financial reports.
- New: A module can add its own ECM view.
- New: A module can disable a standard ECM view.
- New: Add multilang support into product webservice.
- New: Add hooks on project card page.
- New: Add call_trigger method on CommonObject class. So new trigger call within object is just :
$result = $this->call_trigger($trigger_name, $user)
WARNING: Following change may create regression for some external modules, but was necessary to make
Dolibarr better:
- The deprecated way (with 4 parameters) to declare a new tab into a module descriptor file has been
removed. You must now use the 6 parameters way. See file modMyModule.class.php for example.
- Remove the javascript function ac_delay() that is not used anymore by core code.
- Properties "dictionnaries" into module descriptor files have been renamed into "dictionaries".
- Method form->select_currency() has been removed. Use instead print form->selectCurrency().
- Method form->select_methodes_commande() has been renamed into english name selectInputMethod().
- The following hooks are now 'addreplace' hooks: "formCreateThirdpartyOptions"
So check that return value is 0 to keep default standard behaviour after hook, or 1 to disable
default standard behaviour.
- Properties "civilite_id" were renamed into "civility_id".
- Remove add_photo_web() that is not used anymore by core code.
v3.6.1
For users:
- Fix: Can upload files on services.
- Fix: sql errors on update fichinter.
- Fix: debian script syntax error.
- Fix: error "menu param is not inside list" into pos module.
- Fix: Salary payments are not reflected on the reporting sheets.
- Fix: Unsubscribe emailing not working.
- Fix: Trigger on create category call failed because user is not passed on card.
- Fix: list event view lost type event filter.
- Fix: Save also code event.
- Fix: VAT payment - Add control on field date value.
- Fix: Salaries payment - Field date value is now required and add control on it.
- Fix: Iban was used instead of Bic into SEPA file.
- Fix: Must unaccent strings into SEPA file.
- Fix: Extrafield feature select from table should try to translate multiple column when not needed
- Fix: cents for indian ruppes are called paisa and paise.
- Fix: Invoices payments may be older than invoices.
- Fix: Withdrawal total amount is double
- Fix: [ bug #1593 ] Spanish Localtax IRPF not being calculated since 3.6.0 in supplier invoices when adding a line
- Fix: Web service categorie WDSL declaration is correct
- Fix: ErrorBadValueForParamNotAString was displayed in virtual product if no base price defined
- Fix: Category creation failed and no message output
- Fix: Lang for Payment Type
- Fix: PHPCheckstyle 1.5.5
v3.6.2
- Fix: fix ErrorBadValueForParamNotAString error message in price customer multiprice.
- Fix: bug 1588 : relative discount.
- Fix: label of input method not translated.
- Fix: box of customer and prospects were not correctly disabled.
- Fix: [ bug #1618 ] PHP Error thrown when saving a barcode
- Fix: Civility & birthdate wasn't save into adherent module.
- Fix: webservice Thirdparty parameter lastname for individual creation is now lastname and not ref
- Fix: Chars - is no more allowed into value for code for extra fields.
- Fix: [ bug #1622 ] Requesting holiday than spans across two years cause high CPU usage by Apache
- Fix: [ bug #1595 ] Selected boolean extrafield in intervention creation page, does not save state
- Fix: Show sender Country on PDF docs when sender Country <> receiver Country
- Fix: [ bug #1624 ] Use lowest buying price for margin when selling with POS
- Fix: [ bug #1749 ] Undefined $mailchimp
- Fix: [ bug #1736 ] Failing supplier Elephant numeration module with some masks
- Fix: [ bug #1649 ] Cancel button of several thirdparty actions, does the same thing as modify
- Fix: [ bug #1731 ] Can't use quick navigation on project tasks secondary tabs
v3.6.3
- Fix: ref_ext was not saved when recording a customer order from web service
- Fix: withdrawal create error if in the same month are deleted previus withdrawals.
- Fix: amarok is a bugged theme making dolidroid failed. We switch to eldy automatically with dolidroid.
- Fix: [ bug #1788 ] Duplicated doActions hook in product/fournisseurs.php
- Fix: withdrawal create error if in the same month are deleted previous withdrawals.
- Fix: [ bug #1801 ] FAC_FORCE_DATE_VALIDATION constant alters supplier invoice date given to numeration modules
- Fix: [ bug #1802 ] SQL error when updating a task with PostgreSQL database
- Fix: [ bug #1785 ] Start date is lost in Project > Linked objects
- Fix: [ bug #1804 ] SQL error when sending email without address
- Fix: [ bug #1803 ] AJAX company contact input is not aligned
- Fix: [ bug #1787 ] Incorrect behaviour of doActions hook
- Fix: [ bug #1796 ] Unable to use numeration modules from an external module
- Fix: [ bug #1783 ] SQL error when enabling 3rd party module with PostgreSQL and MySQL strict mode ON
- Fix: [ bug #1717 ] Sorting unpaid invoices by amount received brings due amount
- Fix: [ bug #1784 ] MOTD doesn't show up in Amarok theme
- Fix: Tracking number not visible on shipment pdf
- Fix: [ bug #1812 ] SQL Error message while sending emailing with PostgreSQL database
- Fix: [ bug #1819 ] SQL error when searching for an invoice payment
- Fix: [ bug #1827 ] Tax reports gives incorrect amounts when using external modules that create lines with special codes
- Fix: [ bug #1822 ] SQL error in clientfourn.php report with PostgreSQL
- Fix: [ bug #1832 ] SQL error when adding a product with no price defined to an object
- Fix: [ bug #1833 ] user permissions in contact/note.php not working
- Fix: [ bug #1826 ] Supplier payment types are not translated into fourn/facture/paiement.php
- Fix: [ bug #1830 ] Salaries payment only allows checking accounts
- Fix: [ bug #1825 ] External agenda: hide/show checkbox doesn't work
- Fix: [ bug #1790 ] Email form behaves in an unexpected way when pressing Enter key
- Fix: Bad SEPA xml file creation
- Fix: [ bug #1892 ] PHP Fatal error when using USER_UPDATE_SESSION trigger and adding a supplier invoice payment
- Fix: Showing system error if not enough stock of product into orders creation with lines
- Fix: [ bug #2543 ] Untranslated "Contract" origin string when creating an invoice from a contract
- Fix: [ bug #2534 ] SQL error when editing a supplier invoice line
- Fix: [ bug #2535 ] Untranslated string in "Linked objects" page of a project
- Fix: [ bug #2545 ] Missing object_margin.png in Amarok theme
- Fix: [ bug #2542 ] Contracts store localtax preferences
- Fix: Bad permission assignments for stock movements actions
- Fix: [ bug #2891 ] Category hooks do not work
- Fix: [ bug #2696 ] Adding complementary attribute fails if code is numerics
- Fix: [ bug #3074 ] Accruals accounting use payment date instead of commitment date in turnover reports for salaries
- Fix: Not showing product supplier reference when page break
- Fix: [ bug #3341 ] Missing translation in /compta/paiement_charge.php
- Fix: [ bug #3342 ] Taxes dictionary page does not accept localized decimals for localtax2 rate
v3.6.4
- Fix: [ bug #2893 ] Dolibarr error when viewing an invoice after changing invoice mask
v3.6.5
FIX: #2957 : missing $langs object for trigger
FIX: #2983 Load gravatar avatar images securely over HTTPS
FIX: #3009: Better filtering to prevent SQL injection
FIX: #3841 creation of a task completed has not status set to finished by default
FIX: #3890 Expected transactions bank account page, shows negative numbers
FIX: #3928 Creating a Customer order and a Customer invoice from a project, does not inherit payment conditions and method of payment of customer card
FIX: bad stock valo
FIX: bad stock valorisation
FIX: [ bug #2893 ] Dolibarr error when viewing an invoice after changing invoice mask
FIX: button create payment hide if tax amount is less than 1
FIX: change object statut on close shipping and remove erratic db commit
FIX: Close #2835 Customer prices of a product shows incorrect history order
FIX: Close #2837 Product list table column header does not match column body
FIX: Close bug #2861 Undefined variable $res when migrating from 3.6.2 to 3.7.0
FIX: Close bug #2891 Category hooks do not work
FIX: Close bug #2976: "Report" tab is the current tab but it is not marked as selected by the UI
FIX: contact country had wrong display if the country dont have translate
FIX: double db escape add too quote
FIX: End log must use same level then start log.
FIX: error in SQL due to a previous fix
FIX: event for restricted user was restricted if company null
FIX: facturestat bad sql when customer view is limited
FIX: If supplier invoice block linked element is display after other block total HT amount is not reset to 0 and sum other block (like customer orders values)
FIX: keep filter by category or by not enough stock if we switch page
FIX: no need to remove file into mail form, the temp dir will be deleted after any sending
FIX: no projet_task_time id from trigger TASK_TIMESPENT_CREATE
FIX: pmp
FIX: send mail, copy sendto don't read the list of contact
FIX: tool export handle the type "select" extrafields and return the value instead of id
FIX: top links menu have target attribute with wrong value
FIX: total amount in tpl linked object are not reset
FIX: when multicompany was enabled, this function didn't check just on the good entity (problem when both company use same mask)
v3.6.6
FIX: #3734 Do not show empty links of deleted source objects in stock movement list
FIX: #4081 Added missing translation
FIX: #4097 Public holiday calculation
FIX: #4242 Allow disabling dashes in documents
FIX: #4243 sql injection
FIX: Add a protection to not make release if ChangeLog was not generated. Prepare package 3.6.5
FIX: export with category contact extrafields
FIX: Not delete a product when have customer price
FIX: Not deleting contrats on element_element table
v3.6.7
v3.7.0
For users:
- New: Match other auth system: Login can be done entering login or user
email (this open the road for SSO).
- New: Agenda export by project #1967.
- New: Increase length of thirdparty to 128 chars.
- New: "Is Order shippable" icon #1975.
- New: statistics on supplier orders and invoices on home page.
- New: Add permissions to read all trips and expenses.
- New: Can filter on date into tab "Referring object" of a project.
- New: Module notification has been enhanced:
EMail use now language of target contact.
Can also define a fixed email for notifications.
- New: Feature to link manually an order to an invoice does not disappear once
link has been done.
- New: Can set a color on user card (visible into agenda view).
- New: extrafields for projects and tasks are exported to ODT documents.
- New: Add number of active notification into tab title (like we do for notes and documents)
- New: Can add product into category from category card.
- New: PDF event report show project and status of event.
- New: Can filter on status on interventions.
- New: Add help info of field type into dictionary of payment types.
- New: Add proposals into referer page of thirdparty.
- New: On contact list can set filter on both active and not active (no more exclusive select).
- New: Intervention documents are now available in ECM module.
- New: Can attach supplier order to a customer order.
- New: Supervisor is now visible into user list.
- New: Add user of creation and validation on invoice export.
- New: Add info page about browser.
- New: Enable feature developed for 3.6 we forgot to enabled: Adding prefix
on uploaded file names.
- New: No more dependency between contract and service module.
- New: [ task #867 ] Remove ESAEB external module code from core.
- New: Can create proposal from an intervention.
- New: An event can be assigned to several users.
- New: Can filter events on a group of users.
- New: Can filter events of a thirdparty.
- New: Onto event summary of elements, end date and status are visible.
- New: Split Agenda view (month, week, day) into different tabs.
- New: Add a view "per user" of agenda events (with different colors according to type of event).
- New: Each user can include its own external ics calendar into dolibarr agenda view.
- New: Add event FICHINTER_CLASSIFY_BILLED into list of possible events to
create an automatic event into agenda.
- New: Add new type of event (when type of events are used, not by default).
- New: Can disable predefined type of events.
- New: Form to add a photo is immediatly available on photo page if
permissions are ok (save one click per photo to add).
- New: Add option PRODUCT_MAX_VISIBLE_PHOTO to limit number of photos
shown on main product card.
- New: Add country into table of thirdparties type. This will allow to provide
a list of thirdparty types specific to a country (like argentina that
need type A or B).
- New: Can force a specific bank account onto an invoice/order.
- New: Home page of project area shows list of draft project (like other main page).
- New: Can search on project ref or string from project main page (like other main page).
- New: First change to match accessibility rules: http://www.w3.org/TR/WCAG10-HTML-TECHS/
Differentiate text and img.
Use label into quick search form.
Use accesskey on form search.
- New: Add attachments on user card + in ECM module.
- New: Can add __PROJECT_REF__ and __THIRDPARTY_NAME__ into email topic or content template.
- New: [ task #1204 ] add Numering contrat module free (like leopard in product module).
- New: [ task #712 ] Add warning when creating invoice from proposal or order, when there is already one invoice.
- New: Enable supplier price log table.
- New: [ task #1204 ] add a supplier reference to contract.
- New: [ task #1218 ] Can drag and drop an event from calendar to change its day.
- New: Optimize size of image static resources.
- New: Add hourly and daily amount on user card. Add weekly working hours and salary on user card.
- New: Content of predefined email come firstly from table llx_c_email_template, then translation key.
- New: Add option MAIN_GENERATE_INVOICES_WITH_PICTURE to show picture
onto PDF like MAIN_GENERATE_PROPOSALS_WITH_PICTURE dir for proposals.
- New: Add more search field in list of cheque deposits.
- New: Add feature to order to invoice on supplier part.
- New : Use of MAIN_USE_FILECACHE_EXPORT_EXCEL_DIR to use disk cache for big excel export.
- New: Direct invoice creation from predefined invoice.
- New: Add dunning into accountancy report.
- New: Add favorite button into country dictionary to put value on top select list
- Upgrade phpexcel lib to 1.7.8
- New : Option on extrafields to have them always editable regardless of the document status.
- New : New module PrintIPP to print without opening document is available as stable.
- New : Introduce hidden option STOCK_WAREHOUSE_NOT_REQUIRED_FOR_SHIPMENTS to solve at no risk
a missing control on missing warehouse.
- Fix: [ bug #1487 ] PAYMENT_DELETE trigger does not intercept trigger action
- Fix: [ bug #1470, #1472, #1473] User trigger problem
- Fix: [ bug #1489, #1491 ] Intervention trigger problem
- Fix: [ bug #1492, #1493 ] Member trigger problem
- Fix: [ bug #1474, #1475 ] Contract trigger problem
- Fix: [ bug #1496 ] ACTION_DELETE trigger does not show trigger error
- Fix: [ bug #1494 ] CATEGORY_CREATE and CATEGORY_MODIFY triggers do not intercept trigger action
- Fix: [ bug #1502 ] DON_CREATE trigger does not intercept trigger action
- Fix: [ bug #1505, #1504] Project trigger problem
- Fix: [ bug #1463, #1464 ] Proposal triggers problem
- Fix: [ bug #1498, #1499 ] Shipment/Delivery triggers problem
- Fix: [ bug #1465, #1466 ] Product triggers problem
- Fix: [ bug #1508 ] STOCK_MOVEMENT does not show trigger error message
- Fix: [ bug #1501 ] DEPLACEMENT_CREATE trigger do not intercept trigger action
- Fix: [ bug #1506, #1507 ] ECM trigger error problem
- Fix: [ bug #1469 ] Triggers CONTACT_MODIFY and CONTACT_DELETE duplicates error message
- Fix: [ bug #1533 ] Links triggers do not show trigger error message
- Fix: [ bug #1537 ] Difference between societe.nom and adherent.societe.
- Fix: [ bug #1535 ] Supplier invoice Extrafields are not shown
- Fix: datepicker first day of week can be monday by setting into display setup
- Fix: [ bug #575 ] GED doesn't works if there is "/" in a mask
- Fix: [ task #1728 ] Deactivate RIB suggest in proposals / invoices / orders
For users, new experimental module (need to set feature level of instance to experimental to see them):
- New: Module Accounting Expert to manage accountancy
Special Thanks to developpers :
Olivier Geffroy
Alexandre Spangaro
Ari Elbaz
Florian Henry
Juanjo Menent
And to the contributors :
Jeff Info 2000 euros
Nord Anim 120 euros
Hydroflex 120 euros
Asysteo 120 euros
Fournisseur médical 120 euros
- Removed: unmaintained OScommerce module
For translators:
- New: When a translation is not available we always jump to en_US and only en_US.
For developers:
- New: Syslog module can be set to use ChromePHP plugin to output log server into browser console.
- New: Add a css style "cursorpointer".
- New: Select list of users can return user into hierarchy.
- New: getBrowserInfo can return type of layout of browser (classic/phone/tablet)
- New: Add hook "searchAgendaFrom" and "beforePDFCreation".
- New: Add trigger DON_UPDATE, DON_DELETE
- New: Add country iso code on 3 chars into table of countries.
- Qual: Removed hard coded rowid into data init of table llx_c_action_trigger.
- LINEBILL_DELETE, LINK_DELETE, ORDER_SUPPLIER_DELETE, RESOURCE_DELETE trigger called before SQL delete
- New: [ Task #1481 ] Add trigger BILL_SUPPLIER_UPDATE.
- New: [ Task #1495 ] Add trigger LINECONTRACT_CREATE.
- New: Added hook "formConfirm" and "doActions" for supplier invoice card.
- New: [ task #1511, #1426 ] Added hook "doActions" for supplier card and supplier order card.
- New: renamed table llx_c_pays to llx_c_country & libelle field to label.
- New: Added hook "formConfirm" and "doActions" for fichinter card
- New: Can search list of thirdparties from web service on part of name.
- New: Function getCurrencyAmount is marked as deprecated. Use function price to output a price
including currency symbol.
- Qual: Renamed table llx_c_civilite into llx_c_civility,
field civilite into label in the same table,
and field civilite into civility in other table.
- Qual: Renamed all files & links "liste.php" into "list.php".
- Qual: Renamed all files & links "fiche.php" into "card.php".
- Qual: Replace all constants COMPTA_* by ACCOUNTING_*.
- Qual: Replace all constants ACCOUNTINGEX_* by ACCOUNTING_* to simplify migration of the module
- Fix: [ bug #1724 ] Can't add a submenu to projects
WARNING:
Do not try to make any Dolibarr upgrade if you are running Mysql version 5.5.40.
Mysql version 5.5.40 has a very critical bug making your data beeing definitely lost.
You may also experience troubles with Mysql 5.5.41 with error "Lost connection" during migration.
Upgrading to any other version or database system is abolutely required BEFORE trying to
make a Dolibarr upgrade.
WARNING:
Following changes may create regression for some external modules, but was necessary to make
Dolibarr better:
- Path to save photos of products was moved to match path of other attached files. If you had loose your photo
on the photo tab of products, you can set the constant "PRODUCT_USE_OLD_PATH_FOR_PHOTO" to 1 (home - setup - other)
to restore old path and get back working links without having to resubmit images.
- If you can't see trips and expenses records, check that you have the new permission "read all
trips and expenses".
- Deprecated module "oscommerce" were removed.
- Changed the way parameters are provided to scripts sync_xxx_ldap2dolibarr.php
- Some field into database were renamed from "libelle" to "label".
- Table llx_c_pays were renamed into llx_c_country.
- Triggers *_BUILDDOC are removed. Building a doc is not a business event. For action after
creation of a pdf or odt, hook "afterPDFCreation" or "afterODTCreation" must be used instead.
- A lot of pages named fiche.php were renamed into card.php
- A lot of pages named liste.php were renamed into list.php
- If you used warehouse/stock module, recheck setup of stock increase/decrease rules of the
warehouse module and your Point Of Sale module setup if you use one.
- Replaced USER_UPDATE_SESSION trigger with an updateSession hook may break modules using it.
v3.7.1
FIX Bug in the new photo system
FIX Error management
FIX [ Bug #2714 ] Members -> Memberxy-> Agenda -> technical Error
FIX [ Bug #2713 ] 3.7.0 mailing-unsubscribe.php not unsubscribe
FIX #2901
FIX when we create an agenda event with "Not applicable" status, it is automatically saved with "To do" status
FIX check the user status during authentication
FIX top links menu have target attribute with wrong value
FIX extrafields required on thirdparty
FIX create contact with extrafield is null when it is require
FIX width multiselect
FIX "script" tag with wrong syntax
Fix bug debian 786479
FIX update usergroup name
Fix facturestats was not filtering on invoice type
FIX #2856 : Wrong table design
FIX button create payment hide if tax amount is less than 1
FIX event for restricted user was restricted if company null
FIX send mail, copy sendto don't read the list of contact
FIX Properly escape untrusted data to prevent HTML injection.
WARNING:
WARNING:
v3.7.2
FIX: #3091 TotalHT amount in supplier order is bold unlike the rest of Dolibarr
FIX: #3262 Webservice getProductsForCategory()
FIX: #3318
FIX: [ #3460 ] Selected bank account was not saved when an error happened when trying to create a customer invoice
FIX: #3530
FIX: #3630 - Wrong balance report when module salaries and donation disabled
FIX: #3679 Error when deleting a Localtax2 special payment
FIX: #3707 Thirdparty bank account page table has a glitch
FIX: #3724 Bug: Blank page after cloning proposal with changed client
FIX: #3836 Unable to upload a document to an invoice under some circunstances
FIX: adjusted test for affecting supplier reference
FIX: Admin fiche inter page do not take good action
FIX: Avoid warning strict mode when hosting server do not have php5_curl installed
FIX: Bad condition into invoice export request making reporting too many rows.
FIX: Bad visualization of suppliers name on Incomes-Expenses mode
FIX: Better management error into the color conversion functions
FIX: [ bug 1634 ] Error deleting a project when it had many linked objects
FIX: [ bug 1925 ] "Link to order" option in supplier invoices is not working properly
FIX: [ bug #3211 ] Error about sold to pay (Montant encours)
FIX: [ bug #3321 ] Users with certain permissions were shown a "forbidden access" page even if they had the rights
FIX: [ bug #3358 ] Tasks box does not work with PostgreSQL
FIX: [ bug #3383 ] Company name is overlapped with company direction in PDF models
FIX: [ bug #3426 ] Unable to create an invoice from a contract with extrafields
FIX: [ bug #3431 ] Invoice bank account is not respected
FIX: [ bug #3432 ] Spaces should be removed from IBAN when formatting it
FIX: Can create Proposal on close thridparty #3526
FIX: Close bug #2855 Wrong translation key in localtax report page
FIX: Close bug #2900 Courtesy title is not stored in create thirdparty form
FIX: Display country name instead of country id (display country id makes no sense on vcard files)
FIX: display error on extrafields on ficheinter
FIX: Email selector contact must not include inactive contact
FIX: event's data lost on user assign update
FIX: Export of tags for contact and member
FIX: if multicompany enabled, call to undifend method _setCookie instead of setCookie
FIX: Line break display as a block
FIX: load propal langs for availability traduction
FIX: loss data also if update was cancel by error of ended state with no end date, try a generic patch
FIX: Mass Mailing activity don't display all status
FIX: Missing to set context into workflow actions, so triggers can't know we are creating an invoice from order or an order from a proposal.
FIX: multientity warehouse management
FIX: New adherent from, always redirect on entity
FIX: No check warehouse is provided if module stock is not enabled.
FIX: Not showing task extrafields when creating from left menu
FIX: only active customer should be return into new invoice creation select list
FIX: Payed invoices are showed as canceled FIX: Bad date filter on customer order
FIX: WAP calculation
FIX: Save of filters into export profiles failed.
FIX: supplier rights for orderToInvoice
FIX: Syntax error in Debian Apache configuration
FIX: translate Jabberid on contact page with edit view
FIX: translation for 1 word do not work if product/service module are disabled because the translation search in products.lang
FIX: update2.php test res befre assign it
FIX: When delete actioncomm also delete actioncomm_resources
FIX: when fetch_optionnal_by_label in Extrafields with $this->db cannot work because this->db is never instanciated
FIX: when mailing is deleted, the targets list was kept in database
FIX: When we add an user on event in create mode, we lose linked object
FIX: When we automatically creta an order from a proposal with workflow module, if some extrafields of propal don't exist in order object, insertExtraFields() function tries to insert extrafields in unexistant column of commande_extrafields table.
FIX: When we clone a propal, if it has a project which is not assigned to a third, it was not on new propal because fk_project was always set to empty string if new propal is for another third.
FIX: XSS security using the onerror and missing escapement on type of member page.
NEW: Created new ContratLigne::insert function
v3.7.3
FIX: #3980 Search field in "product by supplier" list sends empty result 3.8 and 3.7
FIX: Can use formated float number on old expense report module.
FIX: Change object statut when closing shipment and remove erratic db commit
FIX: Export with category contact extrafields
FIX: NB task and percent progress in box project
FIX: Not use localtaxes when invoice some orders
FIX: Product link in project box
FIX: Use "WHERE true" instead of "WHERE 1" #4132
