The Export Tool, exporting Project is not working!
The report is returning empty value?
Check the fields you select. If you select a field of a task and your project has no task, it will return nothing.
If only selecting field from Project and not task, Its still returns empty?
Hi, I am new and interested in dolibarr.
I have dolibarr 3.5.4 installed and created 3 projects where one contains a task (progress 100%).
When exporting, regardless of choosing some or all the fields, the excel/csv only contains the field titles.
I also tried exporting and during filtering, I choose a project id, it still returns empty.
Can you help?
Thanks
I am facing the same issue with Dolibarr 12.0.3
Complementary Attributes of Resources module not included while exporting
