Please can any one make us available with Indian Accounting system in Dolibarr. it will be very helpful and kind of you.
Regards
Jay
Regards
Jay
Yes, Just pick up the British Accounts which is similar to Indian accounting system. If you want I can assist you remotely
Dolibarr Create Indian COA
Notes:
(1) Use the uploaded file here
(2) Open csv file in Excel
(3) Use Ctrl+H to find MS and replace with âIndian COAâ or whatever
Credit to afiifidali
WARNING: BEFORE ATTEMPTING any of the steps below please BACKUP Dolibarr or backup your Dolibarr database from your control panel. Although the procedures below will not do any serious damage to your system, youâd rather be safe than sorry. I will not be responsible for any system malfunctions.
So here are the steps you need to take. Make sure you carry out the procedure step by step, do not miss any step or it wont work.
STEP 1:
Run the following SQL Queries using phpMyAdmin which can be accessed depending on how you are running Dolibarr:
Once you are in PhpMyAdmin:
On the left hand side make sure the Dolibarr database is selected then look for SQL Tab.
Copy and paste the following query in the box where you clicked on SQL Tab. Make sure it has: Run SQL query/queries on database name_of_dolibarr_db:
//CREATE TABLE your_temp_table LIKE llx_accounting_account;
TryIT
CREATE TEMPORARY TABLE your_temp_table LIKE llx_accounting_account;
This creates a table called your_temp_table
Click on Go button to run the query. If everything ran successfully you should have this message : MySQL returned an empty result set (i.e. zero rows). (Query took 0.1491 seconds.) with a green tick
// done
STEP 2:
Download the attached file English Chart of Accounts.csv
(i) Change file name to Malaysia Chart of Accounts
(ii) Ctl+H in Excel and change ENG-BASE to MS
(iii) Making sure the database selected is the Dolibarr database, run the query below:
(iv) copy/paste in SQL the statement: SELECT * FROM your_temp_table;
(v) click on Go button // it should display 343 rows
(vi) Then look for Import tab. Once you click on Import Tab make sure it says: Importing into the table âyour_temp_tableâ
(vii) Click on choose file then select the downloaded English Chart of Accounts.csv file. Under Format choose CSV using Load Data.
(viii) In the Columns separated with box type: ;
(ix) Click on Go button.
// If its successful you will get a tick and a number of rows will be inserted in the your_temp_table created earlier.
// done
STEP 3:
(i) Copy and paste the following query making sure to Uncheck â âEnable foreign key checksâ then click on Go button:
UPDATE llx_accounting_account SET fk_pcg_version = âMSâ WHERE fk_pcg_version = âENG-BASEâ;
The above query renames PCG99-BASE to MS-BASE
Then run the following query making sure to Uncheck â âEnable foreign key checksâ
UPDATE llx_accounting_system SET pcg_version=âMSâ,label = âMalaysian COAâ WHERE pcg_version = âENG-BASEâ;
// done
STEP 4:
Copy and paste the following query:
UPDATE llx_accounting_account INNER JOIN your_temp_table on your_temp_table.rowid = llx_accounting_account.rowid SET llx_accounting_account.label = your_temp_table.label;
// Uncheck âEnable foreign key checksâ â also results in 0 rows but
// in dolibarr all 343 rows shown correctly
Click on Go button
If its successful you will get something like this: 340 rows affected. (Query took 0.1315 seconds.)
Now check on your Accountancy setup if all is done properly you should now see in the drop down list box: MS-BASE - The base accountancy plan in English
// error 0 rows created
Voila!
Phew! this was quite long!
Give a big thank you if I made your DoliLife easier!!
Download the file below:
CSV file
You need to pick in, Setup Tutorial then go the the Model Chart of Account
You must Click the Step 2 You can find it There
The Load it on Step 3 thereby you can edit add and delete
But You must take note Account Groupings about the Income and Expense
That is one of the core important for Accounting Reports
As you can see I used the France small Chart of Account, Our country does not have Pre-defined Chart of Account. I did it since I do not want to take the risk. This is the safest way.
Table âevklrovp_dolibarr.llx_accounting_accountâ doesnât exist
which modules do you have enabled?
Home, Setup, Modules/Applications, search for acc
which accounting - if any - did you enable?
i have choosen double entry
Dolibarr has detected a technical error.
This information can be useful for diagnostic purposes (you can set option $dolibarr_main_prod to â1â to hide sensitive information):
Date: 20240410205049
Dolibarr: 18.0.1 - https://www.dolibarr.org
Level of features: 0
PHP: 8.1.24
Server: LiteSpeed
OS: Linux divine.herosite.pro 3.10.0-962.3.2.lve1.5.83.el7.x86_64 #1 SMP Thu Nov 23 15:58:18 UTC 2023 x86_64
User Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36
Requested URL: /dolibarr/accountancy/admin/account.php?mainmenu=accountancy&leftmenu=accountancy_admin
Referer: Login @ 18.0.1
Menu manager: eldy_menu.php
Modules/Applications: user, agenda, service, stock, bom, variants, productbatch, export, import, fckeditor, mrp, accounting, projet, eventorganization, categorie, resource, ecm, multicurrency, barcode, bookmark, externalrss, workflow, modulebuilder, holiday, opensurvey, website, expensereport, takepos, knowledgemanagement, recruitment, socialnetworks, notification, hrm, fournisseur, mailing, emailcollector, cron, supplier_proposal, externalsite, adherent, reception, printing, receiptprinter, incoterm, facture, societe, tax, salaries, propal, loan, commande, don, expedition, banque, contrat, paymentbybanktransfer, prelevement, ficheinter, margin, ticket, product
Database type manager: mysqli
Latest database access request error: SELECT aa.rowid, aa.fk_pcg_version, aa.pcg_type, aa.account_number, aa.account_parent, aa.label, aa.labelshort, aa.fk_accounting_category, aa.reconcilable, aa.active, aa.import_key, a2.rowid as rowid2, a2.label as label2, a2.account_number as account_number2 FROM llx_accounting_account as aa LEFT JOIN llx_accounting_system as asy ON aa.fk_pcg_version = asy.pcg_version AND aa.entity = 1 LEFT JOIN llx_accounting_account as a2 ON a2.rowid = aa.account_parent AND a2.entity = 1 WHERE asy.rowid = 2 ORDER BY aa.account_number ASC LIMIT 21
Return code for latest database access request error: DB_ERROR_NOSUCHTABLE
Information for latest database access request error: Table âevklrovp_dolibarr.llx_accounting_accountâ doesnât exist
Okay, does the database named evklrovp_dolibarr exist?
yes sir, all other tables are already there, now i am trying to add the table manually from phpMyAdmin from the field names from above select statements
And Now it worksâŠ
But i wonder, why it is so, from a fresh install, the table has to be created by own. there must be some error in the install script. my doliberr version is latest
what do you mean by latest? we need a version number.
Also, can you try redoing the installation to see if it repeats?
Invalid column count in CSV input on line 1.
after inspecting the file, i found multiple colums in the csv file (splitted data from Column A)
after correcting (by joining data from other colums to Column A), still the problem remains same âInvalid column count in CSV input on line 1.â
I am using Version 19.0.1
downloaded csv file has multiple columns to split long data. i have combined the splitted column data in only Column âAâ by cut & paste.
after changing CSV file, started importing which gave me invalid row count. while inspected, in version 19, three extra fields are there in my database âreconcilableâ, âimportkeyâ, extraparamsâ
so added these fields in existing CSV with values â0;NULL;NULLâ at the end of each row
But after these change, I am getting âDuplicate Entryâ error in SQL in step 2 now
ataching modified IN-BASE csv file
INDIA CHART OF ACCOUNTS.zip (6.8 KB)
Any guidance is most appreciatedâŠ
Thanks in Advance
good thinking about those extra columns.
I wonder if import only adds new and does not update existing records. Is that an option somewhere around the import? I never used import.
Normally if you provide product id and that exist, Dolibarr do an update.
yeah, I kind of expected something like that.
