Quotations do not work
Hi all,
I updated from dolibarr 20.0.3 to 21.0.4 and also changed php to 8.1
since that I cannot open previous created proposals.
I get the message (translatet with ai):
Apparently, there is a problem with this website.
../doli/comm/propal/card.php?id=1687
may be experiencing a temporary issue or may have moved.
Error code: 500 Internal Server Error
The website may be temporarily unavailable. Please try again later.
Invoices and Orders work fine.
Does anybody has an idea how to solve this or how to check whats wrong?
Thanks a lot,
Arnold
Please enable debug level logging in Dolibarr’s setup panel. Then look in the dolibarr.log file in the documents/ folder.
Also take a look at the error log of your webserver/PHP
I guess this is done via the module for logging, but I realized that when I want to open the module section, I get a blank page. see attachment
Can I activate logging somewhere on file-level?
What does your web server log say?
by clicking the modules section, webserver says:
[Tue Oct 07 18:07:10.326428 2025] [proxy_fcgi:error] [pid 3906551:tid 3906649] [remote 213.142.96.122:57007] AH01071: Got error ‘PHP message: PHP Fatal error: Declaration of modNotes::init() must be compatible with DolibarrModules::init($options = ‘’) in ../doli/custom/notes/core/modules/modNotes.class.php on line 184’, referer: ../doli/admin/index.php?mainmenu=home&leftmenu=setup
[Tue Oct 07 18:07:29.691792 2025] [proxy_fcgi:error] [pid 3906522:tid 3906761] [remote 213.142.96.122:57008] AH01071: Got error ‘PHP message: PHP Fatal error: Declaration of modNotes::init() must be compatible with DolibarrModules::init($options = ‘’) in ../doli/custom/notes/core/modules/modNotes.class.php on line 184’, referer: ../doli/admin/index.php?mainmenu=home&leftmenu=setup
by clicking previous created proposals, the webserver says:
[Tue Oct 07 18:12:58.014687 2025] [proxy_fcgi:error] [pid 3980027:tid 3980333] [remote 213.142.96.122:57010] AH01071: Got error ‘PHP message: PHP Warning: Undefined variable $dolibarr_main_db_type in ../doli/custom/propalehistory/default.config.php on line 21; PHP message: PHP Fatal error: Declaration of PropalHist::getLinesArray() must be compatible with Propal::getLinesArray($sqlforgedfilters = ‘’) in ../doli/custom/propalehistory/class/propaleHist.class.php on line 316’, referer: ../doli/comm/card.php?socid=979
Not sure if I should post the complete urls.
Creating new proposals does also not work, the log says:
[Tue Oct 07 18:19:35.560834 2025] [proxy_fcgi:error] [pid 4010444:tid 4010500] [remote 213.142.96.122:57016] AH01071: Got error ‘PHP message: PHP Warning: Undefined variable $dolibarr_main_db_type in../doli/custom/propalehistory/default.config.php on line 21; PHP message: PHP Fatal error: Declaration of PropalHist::getLinesArray() must be compatible with Propal::getLinesArray($sqlforgedfilters = ‘’) in ../doli/custom/propalehistory/class/propaleHist.class.php on line 316’, referer: ../doli/comm/card.php?socid=724
it seams that a module is not compatible…propalehistory
how can I deactivate it on filelevel or in the database?
I switched back to php 7.4 and everything works as it should.
After deactivating the module propalehistory and switch back to php 8.3 I can access and create proposals BUT cannot enter the modules sections anymore
Logfiles says:
[Tue Oct 07 18:34:52.639628 2025] [proxy_fcgi:error] [pid 4064020:tid 4064254] [remote 213.142.96.122:57031] AH01071: Got error ‘PHP message: PHP Fatal error: Declaration of modNotes::init() must be compatible with DolibarrModules::init($options = ‘’) in../doli/custom/notes/core/modules/modNotes.class.php on line 184’, referer: ../doli/admin/modules.php?mainmenu=home
same with php 8.1/8.2
php 8.0 my dolibarr
and same error in log when I want to enter “Stammdaten” (/const.php?mainmenu=home) section
Hi @Arnold
You should deactivate ‘Notes’ module
Thanks a lot!!!
