Yes you totally right. My apologyze (the problem was the module “MyField”
By the way, making an upgrade don’t seem’s to resolve the problem.
I tried to pass from 7.0.1 to 7.0.2 and it’s don’t resolve this.
I install the TimeSheet module, and the install was successful,
but it shows on my Project Section as (French Language), how can I have it in English.
thank you very much and God bless
urgent reply, please
Kamal Bayo
Maybe in Configuraiton -> Traduction and try to find English?
This is not timesheet, it’s the project cost module which was a kind of Proof Of Concept so I didn’t do the translation.
I won’t make any change to the project cost module because I never received a user feedback.
br
How can I change the spanish IRPF tax? If I try to generate an “invoice project” from the module “Leads/Projects” the invoice is generated with the correct VAT tax but 0 IPRF tax.
But if I generate an invoice in the module “Billing/Payment” I get the correct VAT AND IRPF tax
How can I change or modify the spanish IRPF tax in the invoice created with “invoice project” from the module “Leads/Projects”? I need to create the invoices through this module. This will allow me to save a lot of time generating my invoices.
Thank you for your help and best regards
there is a new module version https://sourceforge.net/projects/dolibarr-timesheet/files/4.0/module_timesheet-4.0.6.zip/download
The special taxe are supported by entering this variable TIMESHEET_EVAL_ADDLINE = 1, (home >setup >other_setup) but I haven’t tested it fully
br
https://sourceforge.net/projects/dolibarr-timesheet/files/4.0/module_timesheet-4.0.8.zip/download
4.0.8 change log from 4.0.7
- new: block creation of timespent after the end of event
- fix: add missing trad
- fix: line where only the note was modified were not sent to the server in 4.0.7
- fix: previous week hyperlink not working on slitted week if the first day of the month was a monday
- fix: display hours instead of seconds in the EventAdmin page
- fix: subordinates with LDAP (to be confirmed)
4.0.7 change log from 4.0.3
- new: xlsx, csv, tsv report export for several projects
- new: more flexibility in time enter (support .5, 0 … ctr+v )
- new: (EXPERIMENTAL) support multiple taxes in invoice (TIMESHEET_EVAL_ADDLINE must be set to 1)
- fix: selllist condition compatible with pgsql
- fix: php warnings displayed
- fix: only line modified are sent to the servers (support more task lines)
4.0.3 change log from 4.0.0
- new: chrono status (auto stop)
- new: max value for chrono
- new: default value for chrono (when max is reached)
- new: remove signbox from pdf
- fix: multi line comment in comment display in pdf
- fix: pgsql error of wrong column
- fix: project approval without team approval
- fix: sellect sellist without space between column names
- fix: time display issue
- fix: tabletop display issue on pdf
Hi there.
Is this module the same that it is include in Dolibarr 8.0.3 ?
Thank you.
Even if the time entry screen in the core are from this module, it is not part of the core,
in the core you cannot:
- User and project
- pdf attendance sheet
- Create invoice from time spent
- Chrono function
- Timesheet approval
br
by the way the version 4.0.9 need to be used because the 4.0.8 keeps showing a warning message
