Using NOT NULL clause in extrafields filter syntax
for an extra field I’m trying to set a filter in the list from table.
The following syntax works:
fichinter:description:rowid::(fk_statut:=:0)
But I would like to insert the IS NOT NULL clause but the corresponding syntax
fichinter:description:rowid::((fk_statut:=:0) AND (description IS NOT NULL))
gives me an error.
Which is the correct syntax?
Thanks
If you enable debug logging and look in the dolibarr.log file under the documents/ folder, does that give any clues?
Hi @mgribaudo
Have you tried this one?
fichinter:description:rowid::(fk_statut:=:0 AND !description)
Let me know if it works.
Thanks
Saikat Koley
Thanks @saikatkoley it works!
I am more and more convinced that you are a great resource in this environment :slightly_smiling_face:
@mgribaudo I appreciate your kind words! And thanks for your appreciation!
