Pls who has started using the web portal module in Dolibarr? my login isn’t working, the settings I did like the brand name didn’t show and its like frustrating.
I created a member, used the login details yet it shows authentication error…
Any one with a headway on this?
Thank you
Hi @Absmachin
I haven’t used that yet, but did you check the Dolibarr log and PHP log, please?
Thanks
Saikat Koley
we also want to known which version of Dolibarr you run
I also have this question. We’ve just updated to v22 and noticed this module is now part of the new version. I’ve setup.a test user and I keep getting an error saying ‘web portal not setup’ but I’ve configured everything bar from the logos / backgrounds and the anonymous user as we’re currently working out what permissions (if any) the user account requires.
I tried it, and it worked right out of the box.
But the user management is not really good. As an admin you have to set the password; the user has no chance to create an own one oder even reset it. You have to do all these stuff manually. Lot of room for improvement
I get the same error. I just setup the module to test it, added a used from Third party, but “Web portal setup is not complete”. Also cannot see any information at all.
Is there any more information on the web portal? Anyone got it working?
